AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Plasma Flat Panel Great Found Deals! › Panny 55ut50 $799 at costco
Panny 55ut50 $799 at costco - Page 3
post #61 of 62
Originally Posted by Alan K View Post
Re: U50 versus UT50 - I don 't think the picture quality in 2D is very different. The reviews I have seen on the internet and in Consumers Reports lead me to think the 2D PQ is almost identical. I purchased the 55UT50 rather than a 60 inch set because I have the set on a rolling cart and can adjust my viewing distance. If it is wall mounted and viewed from a distance I would probably opt for the larger set. This assumes you don't need/want 3D and internet streaming . My unit has no buzzing that I can hear and I don't know what rising black level means. The black level on my set is excellent.
Thanks for your thoughts. I think I'll try and find the 60" if I can. I did hear reports of buzzing and floating blacks on the U series, but not enough to know if it's any more inherent to that series as I've seen buzzing mentioned on just about any plasma.
post #62 of 62
My local Costco still has this model in stock at $725. I am guessing that is why they haven't stocked the new S64.
