AVS › AVS Forum › Audio › Speakers › Screws and speakers?
post #1 of 7
Are you able to screw a speaker mount into a wooden speaker that doesn't have a mount without harming the speaker sound or anything?
post #2 of 7
Yes, if you're careful. I bought some used speakers that had the mount and 4 screws still attached. I wouldn't put screws in a little satellite speaker though.
post #3 of 7
Im thinking about putting them in a Polk Audio TSi 200's, what do you think?
post #4 of 7
What style speaker mounts are you planning to use on those?
- Brennan, Outdoor Speaker Depot
post #5 of 7
post #6 of 7
I was thinking of making my own speaker mounts with wood or http://www.bracketsandstands.com/PINPOINT_MOUNTS_AM10_SPEAKER_WALL_MOUNT_BRACKETS_p/am10.htm
I would take in a few factors. Such as the type of wood the speakers are made with (will it crack if drilled?), the depth of the wood and proximity of any internal components, and the weight capacity of the mount.
- Brennan, OSD Audio
post #7 of 7
Yea thats why im not gonna try to mess with it, its not worth testing i dont want to mess up my speakers that wouldnt be good.
  Back to Forum: Speakers
