Touché BllDo, touché!!
AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › The Stonewater Cinema Build Thread
Featured Stories
The Stonewater Cinema Build Thread - Page 8
AVS Top Picks
post #212 of 476
1/5/13 at 2:47pm
- J_P_A
- Trader Feedback: 0
- offline
- 2,476 Posts. Joined 12/2008
- Select All Posts By This User
What did you settle on for a chair rail height? IIRC you mentioned that you were planning to lower yours a bit to accommodate your treatments. I'm thinking something like 24" - 25" for my theater. I know that 32" - 36" is most common, but I've been reading up on it a bit, and that's apparently not ideal. Something like 20% - 25% of your wall height is supposed to be more pleasing to the eye. Of course, that's the answer I WANT, but might not be the right answer
post #213 of 476
1/5/13 at 3:29pm
- Shan
- online
- 564 Posts. Joined 8/2003
I agree that 32"+ looks odd in a house with standard ceiling heights. I think you are right when you are talking about 24" or so.
Here is a good article to take a look at. http://www.thisiscarpentry.com/2010/12/03/misused-confused-chair-rail/
I think a lot of it is going to come down to whether chair rail is decorative or functional. In a theater, I am not sure what would look best. I doubt you would ever want chair rail height near the back height of a theater seat unless you had 16' ceilings, but I am not sure. Would be a good thing to lay out in a program like Sketchup and see what looks best to you.
Shan
Edited by Shan - 1/5/13 at 3:52pm
Shan
post #214 of 476
1/5/13 at 6:56pm
- J_P_A
- offline
Well, this is the second time today that my post disappeared into the Internet ether. We'll try again.
That article is actually what prompted the question. I found it after I got my layout back from Dennis and realized my treatments would need to be lower than the "standard" chair rail height. I've tried to model it in Sketchup, but it's still hard to get a feel for what it will look like when you are actually in the room. It seemed like TMcG is running into similar issues, so I thought I'd ask how others are handling it.
post #215 of 476
1/5/13 at 7:11pm
- Larry M
- offline
- 986 Posts. Joined 7/2007
post #216 of 476
1/6/13 at 6:34am
- JamesB77
- offline
- 202 Posts. Joined 6/2007
- TMcG
- Analysis Paralysis Analyst
- online
- 1,291 Posts. Joined 3/2010
This is not set in stone yet, but currently I have the chair rail height right around 29". Typically speaking, the reason for going with a lower chair rail height is to get acoustic treatments at the point of first reflection, especially for those in the front row whose ears are probably 36 inches off the ground. I might actually put it a bit lower, but having the 29" height allows me to keep the chair rail at the same level the whole way around the room, even in the area above the riser. If I started my chair rail at 24" OC and used a 4" wide chair rail, by the time I factored in the 11.75" riser base I would only have about 10" left under the chair rail. Factor in the height of my base molding and there wouldn't be much left in terms of room for panel molding or anything else.
I have been looking at different molding profiles from a lot of different companies trying to find something different that would go with my overall design theme. After looking at hundreds of different profiles I ended up finding a set of moldings I really liked from a company called Bosley moldings that I think will work well. I ordered a sample of their solid African Mahogany and it has the same overall tone of the veneer I purchased so I requested a quotation, which was in line with my finish carpentry budget. I haven't decided my base molding height, but it will either be 5" or 7" high.
I am also in discussions to alter the size (height) of the panel molding. If I have a 2" Quest Acoustic Panel recessed within my 3/4" veneered finish carpentry, that leaves 1.25" left on the side of the panel to cover with the panel molding. Well, the molding is only 3/8" at its highest point so I want to do something to either build up this molding or use a combination of moldings to achieve the required 1.25" of height. I am also considering the purchase of beveled fabric track to lessen the height of the side panel that needs covered. In this scenario the bevel height is just over 1/2" so I would only need to make up 3/8" after using the existing 3/8" molding. I have some work yet to figure everything out on the finish carpentry before placing my order.
Here are the molding profiles I am looking at:
Chair rail:
Case molding:
Base molding:
Panel Molding:
Crown Molding:
post #218 of 476
1/7/13 at 7:01am
- mcascio
- offline
- 3,546 Posts. Joined 2/2001
Shan
Shan
Hey Guys,
This usually isn't an issue for shorter height rooms, but just make sure that you have your material picked out for above the chair rail. I know GOM material is 66" wide and if you are building fabric frames, you have to allow enough room to wrap it around the frame.
I'd hate for someone to get down the path and find this out the hard way and have to add a seam they didn't plan for. Certain material you can only run one way too.
post #219 of 476
1/7/13 at 11:31am
- NicksHitachi
- Trader Feedback: +1
- Ok, bring on the SUMMER!
- offline
- 2,978 Posts. Joined 7/2007
Chair rail:
Case molding:
Base molding:
Panel Molding:
Crown Molding:
Chair rail:
Case molding:
Base molding:
Panel Molding:
Crown Molding:
Man those moldings are sharp and angular, i would have expected more rounded and flowing lines for art deco design....
They all look nice though.
post #220 of 476
1/7/13 at 11:44am
- Spaceman
- offline
- 1,503 Posts. Joined 11/2009
- TMcG
- online
Yeah, I hear ya. My top carpet pick has plenty of curls to it and the design of the metalwork for the column will also have curves. I figured not everything can be curved and not everything can be angular. Perhaps these are a good compromise. I am open to suggestions if you have any!
I have to tell you that finding a coordinating set of molding profiles in an Art Deco or interesting style has been really tough. Most of the really cool moldings are being made in PVC or other paintable synthetic materials. To make matters worse for my situation, the overwhelming majority of the available moldings are very, very traditional in style. Several companies I came across make some very nice period-correct moldings but charge anywhere from $11 to $24 per linear foot. Uhh....no thank you with that kind of pricing. They were nice, but way out of budget. These were the only moldings I have found so far that seemed close to some period moldings I have seen which still fitting in my budget, especially in the pricier African Mahogany species.
Again, I am completely open to any suggestions, of course, if someone happens to find any moldings that may work. This is all just a work in progress at this point.
post #222 of 476
1/7/13 at 6:11pm
- J_P_A
- offline
Our cabinet shop painted white MDF crown to match the glazed cherry cabinets in out kitchen, and it is amazing how close it is. I'd be really surprised if anyone would be able to tell they are not the same wood as the cabinets. If you think it might be of interest, I can dig up some pics for you.
Oh yeah, the point. If there's a PVC profile you really like, you might come out cheaper having a shop paint it to match for you. Not sure about the cost, though.
post #223 of 476
1/7/13 at 6:15pm
- Spaceman
- offline
I have no doubt you will find something that works. By thinking through all of the design elements ahead of time, as you're doing, you'll end up with a nice cohesive project when it's all done. I have seen some examples of art deco design that incorporate both curved and angular design features, but the stronger ones usually lean one way or the other. I'm excited to see what you come up with.
- TMcG
- online
Sure, I'd like to see it if it is not too much trouble for you to post. I have seen painted moldings before and you are right - they look incredibly real.
As for the moldings above, the most expensive is the case molding $7.52 per lf. Depending on height, the base is around $5.80 per lf. The crown and chair are both around $5 per linear foot and the panel molding is about $1.56 per lf. Given that I only need about 50 linear feet for most of the profiles and about 200 lf for the panel molding, the total damage shouldn't be too bad for all the solid stock. Unfortunately they do not stock these profiles in any species whatsoever, so the first time I would see them is when I receive my delivery.
If you happen to see any moldings - even synthetic moldings - that you think will work, please let me know as I'm still not fully decided on this collection (although I do like it).
post #225 of 476
1/7/13 at 7:47pm
- jdanforth
- GUI Guy
- offline
- 1,095 Posts. Joined 8/2009
Have you considered making your own? You could make these on a routing table or shaper. Just about any good woodshop will have all the tools you need to do it: joiner, planer, tablesaw, shaper. You can get oodles of different profiles... here's an example.
post #226 of 476
1/7/13 at 7:53pm
- jdanforth
- GUI Guy
- offline
post #227 of 476
1/8/13 at 7:33am
- J_P_A
- offline
If you've got the time, Mr. danforth may have the right idea!
I may have misunderstood your previous post. I took it to mean that you found some PVC moldings that you liked, but couldn't use b/c they are not wood. At any rate, here is a pic of the crown I mentioned. You can see a bit of the original white crown above and behind the cabinets, but the crown at the top of those cabinets is the same stuff. I have no idea how they did this, but it even has "grain" in it.
post #228 of 476
1/8/13 at 9:32am
That is some very good finish work. This is where the "Pros" really separate themselves the most is in final finishing.
post #229 of 476
1/8/13 at 9:38am
- Jonny5nz
- online
- 462 Posts. Joined 1/2003
- TMcG
- online
Jon - You must have ESPN (
) because those are the exact moldings I liked when I found them 4 or 5 months ago. In fact I made a recommendation to AirBenji for his Esquire theater with the Memphis molding he eventually purchased and installed in his theater that came from this same company.
The problem I ended up having is that I couldn't find a suitable Case, Chair, Base and Panel moldings that were in the same vein / style as either of these two crown molding styles. I know they can be painted to simulate my finished wood, but I am not aware how much that would cost on top of the high-cost of the molding itself.
Regarding the New York style Art Deco molding shown here....
and here....
I really like this style and see a variation of it being used for the verticals of my perimeter soffit similar to that found in the Bacon Race Theater here...
http://i23.photobucket.com/albums/b393/bigmouthindc/Ds%20Theater/DSCF5336.jpg
and here....
http://i23.photobucket.com/albums/b393/bigmouthindc/Ds%20Theater/DSCF5437.jpg
...and the Merrimont Trace theater which has design elements take from the Bacon Race theater:
http://i1013.photobucket.com/albums/af252/rantonuccio/IMG_4770.jpg
. . . only instead of using MDF with a router and roundover bit I would use flat veneered stock and a piece of panel molding on the leading edge to create a slightly more detailed cascade.
I haven't fully decided yet, but I am thinking that I will have the "cove" lighting mounted on the ceiling and pointed directly toward the vertical of the soffit to have the glow of the lighting cascade downward like this:
instead of the more traditional route of hiding the strip lighting behind crown molding and pointing the light upwards toward the ceiling like this as shown in StockMonkey's Desert Sunset Theater thread:
http://i1133.photobucket.com/albums/m588/stockmonkey2000/BZ1Q2160.jpg
If any molding is easy to swap out, it would be the crown. Unfortunately Bosley molding does not have a similar sleek crown profile. But ultimately I can't focus on just one molding or another - I have to find a family of five different moldings (Base, Crown, Chair, Case and Panel) that have similar styles and characteristics to make a cohesive package. Even the InivitingHome.com website only has one or two specific moldings, but not a whole matching family of moldings between the different types....that's the tricky part IMHO.
I am traveling now, but on my desktop I have several other molding profiles from a few other companies that may work. I'll post them here in this thread when I am able.
Thanks for all the input and suggestions guys!
Edited by TMcG - 1/8/13 at 12:53pm
) because those are the exact moldings I liked when I found them 4 or 5 months ago. In fact I made a recommendation to AirBenji for his Esquire theater with the Memphis molding he eventually purchased and installed in his theater that came from this same company.The problem I ended up having is that I couldn't find a suitable Case, Chair, Base and Panel moldings that were in the same vein / style as either of these two crown molding styles. I know they can be painted to simulate my finished wood, but I am not aware how much that would cost on top of the high-cost of the molding itself.
and here....
and here....
post #231 of 476
1/8/13 at 12:48pm
- AirBenji
- offline
- 1,212 Posts. Joined 2/2009
) because those are the exact moldings I liked when I found them 4 or 5 months ago. In fact I made a recommendation to AirBenji for his Esquire theater with the Memphis molding he eventually purchased and installed in his theater.
) because those are the exact moldings I liked when I found them 4 or 5 months ago. In fact I made a recommendation to AirBenji for his Esquire theater with the Memphis molding he eventually purchased and installed in his theater.Yes - thanks, that was an excellent recommendation! The Memphis crown is perfect in my theater and I get compliments on it regularly. I am probably going to use more molding from that company when I attack a master bedroom remodel this year.
Looks like you have some really great ideas and the beginnings of an epic theater here TMcG. Keep up the good work!
post #232 of 476
1/8/13 at 3:36pm
- J_P_A
- offline
Thanks, we're very pleased with how everything turned out. I have to admit, though, our builder brought a lot people over to look at that painted crown molding
It's even more impressive in person where you can see the grain in it clearly.TMcG, that's a cool lighting effect in that image. Is the ceiling in that pic below the lights? It looks like the star ceiling is dropped down a bit, and the lights are hidden underneath. Or am I looking at it wrong?
- TMcG
- online
You are correct, the fiber optic star ceiling is several inches lower than the soundproof shell to allow space for the cove lighting immediately above the star ceiling panels. I used to have another close-up picture that shows the lighting recessed about 4 inches from the edge of the star panel and pointing directly at the vertical edge of the soffit. Like I said, I am not decided on this approach but I think either this way or the more "traditional" route of uplighting from behind crown molding in a cove eminating from the soffit will look nice. Opinions are welcome, of course!
I cannot believe the incredible job your painting guys did on that molding. Absolutely perfect tonal match with all the "natural" variations and graining you would expect with real wood trim. Do you know if this was expensive to have done or was the cost wound into the cost of your cabinetry / trim package. The only reason why I ask is if I decide to go with the "Miami" style of crown molding, it is also available in a flexible format from that molding company and I could incorporate a curved design. Of course I would need it painted if I went that direction and I have no clue if that's a $5 per lf proposition or a $20 per lf proposition.
Thanks for your input JPA!
- TMcG
- online
Thanks Benji! I'm glad to hear you really like that molding option. The way you painted it really works with your theater. I wish I was as creative as you painting it as you did.
I'm glad to have you following along. It was actually in your thread I first heard of Procella speakers and started doing the research which led me to actually make the purchase of a full system, minus subs. I know you gave me a standing invite if I found myself in upstate NY ....same is true if you find yourself in Charlotte, NC!
post #235 of 476
1/8/13 at 6:01pm
- J_P_A
- offline
It was included in the costs of our cabinets. They didn't even ask about different ways to address the crown in the kitchen. They just took care of it. I was here when they picked up the stick of crown to take back to their shop. I'll see if I can find out what they would charge to do moldings in my theater. It's a local cabinet shop that I've bought wood from before, so they seem to be willing to entertain little odd DIY jobs.
post #236 of 476
1/9/13 at 7:58am
- AirBenji
- offline
I am following along intently but quietly. Not sure I could add too much to your already very well thought out build! Keep up the good work and ideas!- TMcG
- online
post #238 of 476
1/9/13 at 10:35am
- RTROSE
- Lets play Colts Football!!
- offline
- 6,025 Posts. Joined 12/2005
Better to be thought a fool than to open your mouth and be proven one. That is why I too follow many build threads, but post in few of them unless it is to provide encouragement, or to actually provide something of merit to the discussion/issue at hand.
I do like the lighting concept that you show in the picture. A different and unique look but to me it does appear rather bright, unless it is just turned up to show the affect.
RTROSE
RTROSE
post #239 of 476
1/10/13 at 2:54am
- Reddig
- HT Addict
- offline
- 558 Posts. Joined 6/2009
- TMcG
- online
Well, I guess I have 847 posts of proof for my own foolish ramblings!
A BIT OF AN UPDATE:
- First and foremost I found out that I will NOT need surgery to repair my foot injury, just physical therapy 3 times per week for 6 weeks and some rest. Not total rest, but not overdoing it either. So I might start trying to tackle a bit in the basement and theater, probably the electrical or something else relatively low-impact that doesn't involve carrying 5/8" sheets of drywall.
- My piece of 1/4" clear glass that I need as a backer to all these 8"x8" alabaster samples is supposed to be ready for pickup today. The alabaster panels I intend to use in the columns will be 16" wide by 72" tall (approximately). I have some melamine and some words of wisdom from the lighting designers at Color Kinetics in order to successfully backlight this alabaster. I can't wait to see the full-scale mock-up in action. I'll be sure to take pictures throughout the mock-up process. If I get really ambitious I will be getting a bit "artsy" and cutting out the decorative metal pattern out of cardboard or 1/8" hardboard to see how the design looks in front of the backlit alabaster panels. I have several different designs I would like to try before committing to the metal fabrication.
- I know I have not put together a full equipment list yet, which I will do in a subsequent post. Some of the equipment decisions have been made and purchased, but the large majority is still subject to debate. One thing is for sure....I will NOT be buying any equipment that ages quickly from a product life-cycle standpoint ( like the projector, automation system, preamp / processor, streaming client, DSP, etc.) until I absolutely need it and am practically waiting outside for the delivery in terms of need. The speakers, anamorphic lens, screen frame, Seymour screen material, speaker wire, power protection system and amplifiers all have been purchased and are waiting in the wings for their installation, but these items don't really change or lose their value with time. It's actually kind-of nice knowing that these major components are bought and paid-for with a relatively minor amount of head-end electronics left to buy.
- Quite unbelievably, I found a guy on Craigslist that was selling a completely brand new set of FOUR Buttkicker LFE transducers, the amp, the connection kit - absolutely everything including T-shirts and other Buttkicker swag for $450. Considering just the transducers go for $275 each, I jumped on the deal. I had planned to wire for Buttkickers for all the theater seats and buy the theater seats without the Buttkickers (but have the framing and the "spot" for them) to save money up front and spread the cost of the upgrade over time. But at that price for the total package I jumped immediately on the deal so at least my primary row of seating (on the riser) will be fully functional from Day 1. The Buttkicker LFE device is TONS more powerful than the little $100 add-on accessories sold and factory-installed by so many seating companies....it should make a big difference in the end result.
- If I have the time, I may build the mockups of my perimeter soffit / ceiling cove lighting to illustrate and see the difference between the two lighting approaches. I'm be looking for opinion and feedback on this as well.
Well, that's all for now in my limited mobility condition. I'll get the updates out when I can.
Back to Forum: Dedicated Theater Design & Construction
- The Stonewater Cinema Build Thread
AVS Top Picks
Currently, there are 1490 Active Users
(354 Members and 1136 Guests)
Recent Discussions
- › Official Samsung PNxxF8500 Series Discussion Thread [No Street... 53 seconds ago
- › Buttkicker question! 1 minute ago
- › Acoustic Transparency of Spandex - The Truth 2 minutes ago
- › PlayStation 4 2 minutes ago
- › New DVDO iScan Duo [2.0 firmware released] 3 minutes ago
- › PLAY ANY VIDEO ON 360 3 minutes ago
- › Official Vizio M-Series Razor Mxx1i thread 3 minutes ago
- › video solution for restaurant 3 minutes ago
- › Chattanooga, TN - HDTV 4 minutes ago
- › 2008 Samsung HL61A750 LED DLP owners thread and FAQ 4 minutes ago
View: New Posts | All Discussions
Recent Reviews
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › BenQ W1070 1080P 3D Projector by jakob_s
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
- › Peerless PRG Mount, Black by DDT0C
- › Epson 5020UB Powerlite Home Cinema 3D Front Projector by DDT0C
- › Sony VPLHS20 Cineza Digital Home Entertainment LCD Projector by varkeast
- › JVC DLA-RS45 Home Theater Projector 1080P HDMI by jmccarei
- › Sharp DT 510 DLP Projector by rdcollns
- › Onkyo TXNR801 / TX-NR801 / TX-NR801 7.1 Channel Digital Home... by mswope63
View: More Reviews
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
View: New Articles | All Articles
Home | Reviews | Forums | Articles | My Profile
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
