AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Pandora log in problem
Pandora log in problem - Page 4
post #91 of 97
In order to use Sirius on your Pioneer receiver, you must have a Sirius internet account. It is not enough to simply have a regular account. You have to also purchase the Sirius internet add-on, which will also allow you to access Sirius on your iPhone, iPod Touch, or iPad. Hope that helps.
post #92 of 97
Getting a "Can't Connect" on opening Pandora in AVR-3312CI. Firmware updated and no change. Pandora loads on PC, so not a port issue.
post #93 of 97
Originally Posted by sweh View Post
FWIW, this may depend on the technology used to login. My Pioneer 1022 AVR gets "server error" and won't work but my Sony S590 BD player authenticates and plays just find. Fun fun fun!
Yep, my Sony TV handles the change flawlessly and transparently, not so much as a hick-up. Pioneer dropped the ball on this one.
post #94 of 97
[EDIT]
Pandora came up a couple hours after my post. Scratch the last info.
Edited by AudioSerf - 2/11/13 at 9:31am
post #95 of 97
I got the SC-61 unit back from repair and set it up again. The Network functions are back. Different IP but that's ok. I had a USB drive plugged in and went to the Update section and found the drive had nothing on it so I swapped it for another drive (USB 2.0 Card Reader with SanDisk 512MB UltraII Stick) and restarted the update. Successful update in no time. Yea.
So the repair shop said they replaced a component but didn't relate what it was. Can only guess but whatever it was, that was the culprit all along.
The unit's back, wired up and is updated. The app on my phone recognized it as SC-63. So I'm guessing the guys at Stewart Bros put a new NICard from Pioneer in. And the SC-63 card replaces the "hobbled" card of the -61. The update performed quickly and flawlessly.
post #96 of 97
what kind of flash drive did you use?
post #97 of 97
It's highlighted bold in my post.
