Hello,
I have been recording old home movies to my computer using the elgato video capture device. I have also tried with a tv tuner card. Both gives the same results.
The issue is that the video capture records a "jiggle" when camera is being moved around a lot. However, it doesn't show up when I play directly to the tv.
Here is an example: http://www.youtube.com/watch?v=wFAJba3VxFY
Any help would be appreciated. Any software or hardware that can help with this? I tried running it through the tv then to the card, but it didnt work. The jiggle still shows up. I assume the Tv out is just a pass through. Something on the tv is stabilizing it. What can i put between the VCR and the tuner / elgato device to do the same? or is thee some software for this?
