AVS › AVS Forum › Video Components › Video Processors › Best processor for 1080i deinterlacing ?
post #1 of 3
I' currently have a Lumagen Radiance XS3D but I'm very disappointed from its 1080i deinterlacing ... so I'm planning to get another processor for that purpose: which is the best in your opinion ?
post #2 of 3
interesting! what exactly do you dislike about the Radiance's 1080i deinterlacing ? It's usually on a very high quality level, so I'm suprised that you're complaining. Maybe it's just a wrong setting ? With the current firmware there are obviously problems with 1080i50 deinterlacing, so maybe that's what your're seeing (if you're from Europe) ?
There aren't too many current video processors out there to chose from. You might want to try a DVDO processor. Their 1080i has become excellent over the years. If you keep your Radiance (for CMS and other gimmicks), you could try a DVDO Edge ($250 used, $500 new) and just put it before the Radiance for your 1080i sources.
Edited by Fudoh - 11/30/12 at 1:34am
post #3 of 3
Thank you for reply Fudoh.
I had the Edge just before Radiance and I found it way worse.
Maybe I just have to wait for a better firmware update (since other owners are complaining with 1080i50 deinterlacing...)
  Back to Forum: Video Processors
