AVS › AVS Forum › Audio › Speakers › Quick question about Frequency Response (help me understand)
post #1 of 6
To start with I do understand that frequency response is not the "end all be all" of what makes a good speaker.
What I don't understand though is it better for the number on the left to be lower, or higher?
For example the NHT Absolute Towers that I was thinking about say their response is 58-20,000 Hz. Those are $500 a piece. Where as say JBL Studio 570's have a response of 45-40,000 Hz.
They both cost the same yet as you can see the left # is far higher on the NHT's but the right # is far higher on the JBL's.
The left numbers represent the lower frequencies (bass) and the right numbers represent higher frequencies correct??
If so wouldn't you want the # on the left to be lower and the # on the right to be higher, thus making those JBL's stats wise seem to destroy the NHT's?
post #2 of 6
http://www.independentrecording.net/irn/resources/freqchart/main_display.htm
Frequencies are arranged from left to right with an index across the top.
Humans hear from (at best) a low rumble of 20hz to a piercing whine of 20khz.
All else being equal: you'd want that first number to be as low as possible and that second number to be as high as possible.
Of course not all is equal (and there's a lot more to perceived sound quality than frequency range)
But here's one of the most important parts to remember in a modern system... you likely have a subwoofer.
I don't need the bookshelf speakers in my home theater to play 30hz, because my subwoofer does that for them. All I need is for that first number to be low enough for the subwoofer to meet it.
In your example: both of those speakers would pair well with a subwoofer and you would no longer hear a difference in how low they went.
If you ran sans-sub; you would get more "rumble" and more low-frequency "presence" out of the JBL's you listed (in all likelihood)
post #3 of 6
How many db down is the response at the frequency extreme's? One could be 3db down and the other 10db.
post #4 of 6
Though there are companies gaming the system, the norm is to report at -3db. Some report at -6db to get the number a few hz lower.
There are actually more factors that come into play than that even. Let's assume -3db@40: is the slope after that 6db/octave or 12db/octave? That's the difference between giving you -6@30 (ish) and -9@30 (ish). How a speaker rolls off below its bottom rated frequency (and above its highest) can certainly matter.
post #5 of 6
+1. Claimed frequency response numbers without measured SPL charts to back them up aren't worth diddly squat.
post #6 of 6
It doesn't have to be an actual graph. A statement of maximum deviation (+/- 1.5db) give much of the same information.
Though I prefer a graph. (then again: I also want to see the off-axis graph as well, and a waterfall plot would be nice)
  Back to Forum: Speakers
