AVS › AVS Forum › Display Devices › Direct View (single tube) CRT Displays › Oddball JVC 7-pin Y/C to Standard S-Video?
post #1 of 12
I picked up a JVC VM-R190SU monitor last night that has these connectors on it for S-video in and out:
It's called a JVC 358 connector, or EIAJ 7-pin connector, used for old video cameras and JVC's own S-VHS decks. I'd like to get adapters (or cables) so that I can plug in a standard s-video mini-DIN. Anyone know where I can source something like that? I realize I may have to roll my own.
post #2 of 12
They look like "Hirose" connectors.
post #3 of 12
Originally Posted by daskrabs View Post
I'd like to get adapters (or cables) so that I can plug in a tandard s-video mini-DIN. Anyone know where I can source something like that? .
Any info in regard to an adapter/converter as requested by the OP?
post #4 of 12
I haven't googled any for him....have you?
post #5 of 12
Whether you believe me or not.... yes I did. I could not find any Y/C 358/422 cable converter/adapter to standard S-Video DIN. I also searched around for "Hirose" to no avail. Therefore.... refer to post #3.
Any enlightenment would be appreciated by everyone
post #6 of 12
post #7 of 12
post #8 of 12
Based on what can be seen on the links provided, it's appears the "connectors" can obtained, but no "converter/adapter" (from 7 pin to standard 4 pin DIN). So.... I guess the OP will have to make a conversion cable/connector.
post #9 of 12
Yeah, he mentioned that in his opening post....but hey, thanks for contributing wink.gif
Edited by SAM64 - 12/2/12 at 8:29am
post #10 of 12
As always, you're correct again. I did read his opening post. But hey... your "contributions" deserve a thanks also.tongue.gif
post #11 of 12
Thanks to all for the responses. I've decided to roll my own cable for the input with an s-video cable I have laying around and this:
http://www.digikey.com/product-detail/en/RPC2-12P-7S(71)/HR1816-ND/1125811
And for output there's this:
http://www.bhphotovideo.com/c/product/133514-REG/Comprehensive_S4P_S7P_6HR_S4P_S7P_6HR_Male_S_Video_to.html
post #12 of 12
I wouldn't mess with all that. Instead, I would just open the monitor and solder in a normal s-video connector. Solder points will probably be large and impossible to mess up.
