Originally Posted by
sgbroimp
Thanks. I see the issue using the Ortek itslef or its command set. Any other device listed by Harmony I could pull standard commands from?
Standard commands? Yes, Ortek or Adesso ARC will have the standard commands.
But good Ortek mouse commands aren't in the harmony database under any device. Microsoft and others are totally incompatible with the Ortek, both the standard and mouse commands. You can keep experimenting with raw learns of the mouse. I won't say it's impossible, but it will be very difficult and probably not worth the effort.
EDIT: I just realized you said you have the same issue with the Ortek (remote I assume). Mine is smooth as silk, both on the original and all my universal remotes. If the original is jumpy, then the problem is your PC, dongle or IR interference, not your remote(s).
Edited by mdavej - 12/3/12 at 12:39pm
