Hello all.
I followed something similar to the way BIGmouthinDC showed in his riser construction (thank you sir!) but now I've read too far into other threads and being a noob I've gone and confused myself.
These are 2x12s, do I need a gap under the joists? I was going to use 2x10s or something like the other thread showed but I thought that was just for saving a few bucks and since the price was basically the same I kept it simple and used only 2x12s but now I worry if I should have space under the joists for air to flow? Maybe this only matters if I plan to use it as a bass trap?
That's where I really got over my head, the bass trap. The sub(s) will not go directly on the riser, I don't have the sub yet so I don't really know what the bass sounds like in there just yet. I have everything else but my sub isn't that great so want to get a new one. Is it a good idea to go ahead and drill the holes on the wall facing boards on the riser or is this something that must be tuned to how the bass works out in the room? Carpet will be going over this and I'm not doing the carpet but I'd assume with this pushed up 1/4 inch from the walls in the corner that they won't carpet those sides facing the wall so those holes would then be uncovered. Part of me wants to just insulate this riser and put the top on but I don't want to regret skipping something.
Another question, I already had carpet padding down from the previous carpet. Is this good to go between the floor and the riser or should I use 30# roofing felt. I have that on hand but wasn't sure if one would be better than the other here. Seems like both serve it's purpose for moisture but didn't want to leave the pad under there if it's going to have a negative affect with sound that I'm clueless on.
Finally, didn't realize there were so many types of insulation until starting this room. Would some pink R-19 serve it's purpose to fill the riser or do I need to go with this mineral fiber stuff or something more for acoustics?
Otherwise, I plan on following what I was reading and putting 2 to 3 layers on top, carpet and will have some lights. Feel like maybe I'm worried too much about it but really don't want to have the carpet go down and then have to pull it back to fix something I could have done better with some more effort.
Thanks in advance
So I put vents on the back sides and front and none on the top. Again, not sure if I wasted my time, but is sounds more solid and does not resonate.
