AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › Official JVC DLA-RS46 / DLA-X35 owners thread
Official JVC DLA-RS46 / DLA-X35 owners thread - Page 40
post #1171 of 2067
I set the projector to user 1, standard, eshift off, and still makes that noise, it makes no difference with eshift off or on. I think there may be a issue with this projector.
Jvc seems to think its the bulb and needs to settle in, we'll I have 260h and still does it.
My hd990 ended up having that magenta strip issue and only had 1000h, now this issue with the x95, so much for the hand picked parts, they must of got the parts at a garage sale.
I had a Sony 70" sxrd and had the same problem with that magenta strip, tells me there is a problem with this technology.
I love the picture quality but If it has to go on for repair, I am finished with jvc
post #1172 of 2067
Originally Posted by plissken99 View Post
I like the bookshelf idea, that IKEA case is about 10in too short(price is right though), but I'll keep an eye out. I think an A/V rack is the ticket, mine is about the right height, but all it's shelves and top are spoken for, never mind the unacceptable light on the screen. .
here's a few other options that might be closer to the right height
http://www.walmart.com/ip/Prepac-Two-Sided-Spinner-528cds-Storage-Unit/17632011 only a foot deep though
http://www.walmart.com/ip/Mainstays-Black-Audio-Pier/20666499
http://www.walmart.com/ip/Sauder-Vinegate-Storage-Tower-Antiqued/7801563
http://www.walmart.com/ip/Hometrends-Media-Tower-Black-Cooking-with-Calphalon-5-Quart-Hard-Anodized-Nonstick-Chili-Pot-with-Lid/15708309
http://www.walmart.com/ip/Whalen-5-Shelf-Audio-Video-Tower-Brown-Cherry/26905822 only 48" high though, not sure what your min height needs to be
http://www.walmart.com/ip/Whalen-60-Six-Shelf-Audio-Video-Tower-Brown-Cherry/21984442 60" high version of above. getting a bit pricey though
http://www.walmart.com/ip/Designs-to-Go-5-Tier-Media-Tower/10082755 49" high
i'm sure there's a bunch more, that was just what I saw from the first page
post #1173 of 2067
My RS4810 does it and two RS46s I had (in case you're wondering -- first had two stuck pixels, second I swapped for the 4810) also did it. I think it's the bulb but I wouldn't worry about it if I were you. I've seen other posts where other folks have noticed the same thing; I just think the majority of people either can't hear it (since it is rather high pitched) or don't care. The projector is almost directly over my head and I can't hear it when I'm watching a movie. I only hear it if I'm located in front of the projector such that the vent that the noise comes from is pointed at me.
Edited by Schwa - 10/7/13 at 6:16pm
post #1174 of 2067
Wow thanks man! The second and last options would do nicely.
post #1175 of 2067
no problem, just make sure they are deep enough first. i think both are only about 15" deep, looking at my x35 i'm not sure that's enough.
post #1176 of 2067
What I am trying to understand is how do ya'll have your projector so far high on the back wall and still sitting upright. i.e. most projectors bottom off lens is almost in line with the bottom of the screen or if mounted on ceiling the image is rotated and now the bottom of lens is in line with the top of the screen. Is there some shifting you are using or are your bottom of the screens so far off the ground?
post #1177 of 2067
Shift is what makes it possible, and it's necessary for high power screens, being retroreflective the lens needs to be at or near the center of the screen for the full effect of the brightness.
Not terribly concerned about the depth and width of the furniture as I can just take the brackets off my shelf and put it on top of whatever I buy.
post #1178 of 2067
Believe it or not, despite the fact that the RS46 is unchanged for 2014, there is a pre-order deal. If anyone is interested, call us ! And soon.
post #1179 of 2067
is it better than the 'clearout' deal on the RS46 from last year? tongue.gif
post #1180 of 2067
There is no " clear out deal ", since last years RS46 is also this years brand new RS46 ! biggrin.gif
post #1181 of 2067
What are you referring to? AV Science did not have a clear out deal on the RS46.
post #1182 of 2067
post #1183 of 2067
Originally Posted by fleaman View Post
post #1184 of 2067
Did not know if the emoticon was referring to the statement or to the clear out deal, since there were clear out deals, just not on the 46.
post #1185 of 2067
just wondering about the lens offset . if i buy an x35 can i ceiling mount it so that the lense centre is level with the top of the screen?
thanks in advance. this is with a 105 inch diag screen
Edited by jeffwp - 10/11/13 at 6:44am
post #1186 of 2067
If you have the lens centered, (or close to centered), on the screen horizontally then you will certainly be able to setup the lens so that it is vertically aligned with the top of your screen.
Page 21 of the manual...
http://pro.jvc.com/pro/attributes/PRESENT/manual/dla46_56_66_48_manual.pdf
post #1187 of 2067
just making another comment on the absurdness of having a 'pre-order' for a product thats been available for a year. no worries smile.gif
but hey, if jvc want's to cut us all a deal, i'll take it
post #1188 of 2067
i ran into issues with this, i was hoping to keep my projector as high as possible, and with the minimal amount of horizontal shift i needed, i wasn't able to do this. i had to move my projector down about 3inches to make it work.
post #1189 of 2067
showing friends the pj:
Waiting for my X35 to come in, friends are already asking for a preview.. Does it do any damage to turn the pj on , show how good it is then shut it off after about 15 minutes of the movie/football game? thanks in advance, can't wait for mine..
post #1190 of 2067
Depends how often. Lamps age from both hours used and " strikes " - the number of times you turn it on and off. Short use once in a while - ok. On and off for 15 minutes 20 times a day every day - probably going to need a new bulb sooner than you would have normally.
post #1191 of 2067
Thanks Craig for quick reply. Guess I'll get everyone together and show all at once..biggrin.gif
post #1192 of 2067
My first projector, an RS46, will be delivered later today, and I'm trying to decide which movie to watch first this evening!
Suggestions and discussions in this thread:
http://www.avsforum.com/t/1494523/new-projector-arriving-today-which-movie-to-watch-first
post #1193 of 2067
I've always been curious about that logic (not disagreeing with it!). People always say not to turn on and off projectors because of wear and tear on the lamp. Is there any scientific proof of this? I remember hunting for some info a while ago, and never could find anything. frown.gif
I'm also curious about situations, in general:
I watch a movie for 2 hours, but then I have to leave for an hour. Should I turn the projector off and then turn it on again an hour later? I don't know! biggrin.gif
post #1194 of 2067
While I don't have an absolute answer for you, for me it would probably be better for the PJ to leave it on. Even with the lamp out of the equation, PJ's have a HUGE temperature swings between on and off. We all know that cycling electrical components on/off wears them more than leaving them 'on' for the same period (say a 2 hour period). Add huge temperature swings into the equation and you get way more expansion and contraction of components = more wear of components.
That being said, because PJ's DO get very hot, I myself would turn it off if I leave the house, 'cos I'm a little paranoid of the fire danger.
post #1195 of 2067
just research light bulbs. even the standard tungsten light bulbs have severely reduced life cycles with constant on/off usage.
I usually try to organize myself a little better, and do all my projector viewing in one shot. eventually my plan is to pick up a second LED/laser projector to use for casual viewing in situations similar to what you describe.
I would also turn my projector off if I wasn't going to use it for an hour. I don't know if that will extend or shorten lamp life in the long run, but it'll save electricity, haha.
post #1196 of 2067
I haven't seen any mention of lamp brightness lately. I had to put new batteries in my Lux meter and so I checked my X35 at the end of a viewing session (as opposed to just after switch on). I've had to move the aperture from -15 to -14 to maintain 100 lux at my screen (equals 14fL). This is after 270 hours on the lamp, still running in Eco mode. I have to run at -8 for 2.35:1 content which again is one click up from when new.
I thought it might make a nice change for someone to post that they are happy with their projector and not post about some problem. smile.gif
post #1197 of 2067
Sure, light bulbs have reduced life, depending on the bulb, though.... I've been living in this current house for 4 years, turn lights on and off a zillion times a day (new house), and have never replaced a single bulb yet. Technology has improved so much.
It really would be interesting to see some scientific numbers - actual test results - on that sort of thing in 2013.
post #1198 of 2067
I don't have a meter, but i'm still quite happy with the brightness of mine at -15 after 230 hrs.
unfortunately I can't be all rainbows and sunshine though. my x35 has starter to flicker. I searched and saw some earlier posts about this, some ppl mentioned it went away in high bulb mode. so I tried that and it better, but not 100% resolved. my projector was packaged in with a spare bulb, that unfortunately I may be forced to use way too early. but i'm wondering if there's been any development on this issue? any fixes, settings to minimize/prevent it. specific bulbs that were an issue?
the projector's been a dream come true until this point. I can make due with high bulb, but I much prefer the low lamp mode.
post #1199 of 2067
unfortunately I can't be all rainbows and sunshine though. my x35 has starter to flicker. I searched and saw some earlier posts about this, some ppl mentioned it went away in high bulb mode. so I tried that and it better, but not 100% resolved. .
Run it in high lamp for some hrs (say 2-3 movies worth), then switch back to low lamp.
post #1200 of 2067
didn't even take that long. what are the chances of the flicker returning though? guess i'll have to calibrate a setting for the high lamp mode just in case.
I left it on high for about 30mins while making the last post, and finishing the last 10mins of the movie I was watching. then flipped it back to low and watched White House Down, and it hasn't returned so far.
at least I've got a strategy to deal with it now, thanks
