Originally Posted by AV Science Sales 5
One thing to keep in mind, when projecting onto a wall, it is very hard to determine if the image is square. This is because you do not have a perfectly square frame to project against. If the image is not perfectly square, then focus can't be completely uniform edge to edge.
I think what Mike is trying to convey is not the square shape that a frame makes but having the plane of the wall exactly match the plane of the lens. This of course would have really nothing to do re the shape or outline of the frame but as to whether the wall is perfectly flat like a stretched fabric on a frame would be . One could indeed project a rectangle (the 16/9 one generated by the chips on a wall and simply measure the top and bottom and the sides getting them the same Top and bottom of course longer than the sides and even measure with a protractoe to get 90 degrees without having a frame to mimic. But unless the wall is flat and most aren't, the focus could be off.
Edited by mark haflich - 12/14/12 at 6:14am
then I just use my 2.35:1 setting (the one with more iris opened) to combat some of the ambient light assuming I'm watching 16:9 which most TV seems to be anyway.
