AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › Official JVC DLA-RS46 / DLA-X35 owners thread
Official JVC DLA-RS46 / DLA-X35 owners thread - Page 2
post #31 of 798
I just ordered my x35 today.
it'll arrive in a few days.
I'll have epson 5020 as well and comapre them together.
If x35 isn't any better than epson 5020, i'll probably keep epson and sell x35 or something.
we'll see...
post #32 of 798
I have the RS46 on Pre-Order (Thanks Mike for all the help over the last 2 months). Almost done with my theater room (14.6' L x 12.2' W). I ordered my Monoprice 120" Multi-Format Screen last week.
I'm excited as this will be my first HT. Im guessing at 13 feet, 120 screen is going to look like IMAX.. lol.
post #33 of 798
post #34 of 798
Krain, can't wait to for your post on both 2D and 3D quality. Hope flicker and ghosting issues are solved.
post #35 of 798
Kraine.
Let us know how different this model is compared to the preproduction model you had. Especially the lumens.
post #36 of 798
Thanks for the photos! I am worried now about using a DVI-to-HDMI adapter for the second input for my PC now (already have DVI run) since they're side-by-side, but if I need a 1ft cable I can do that.
Should I plan on running a Cat5e/Cat6 cable alongside my HDMI? I see there's a plug for it but no word on what it does?
post #37 of 798
Why don't you do a dvi-HDMI adapter on the PC side and run HDMI to the jvc
post #38 of 798
Last day for the preorder for this projector.
post #39 of 798
Does that mean the rs46 ship tomorrow?
post #40 of 798
I'm also curious about the functionality of the rj-45 port. Can it be used for firmware updates? I remember reading early on that this year's JVCs would be controllable via an iOS / Andriod app so that could be it's main function for end users. I never saw anything else about the app though, so I don't know if it will be a feature across the range, or limited to the higher end models.
post #41 of 798
Ghosting is still there on the X35 :
post #42 of 798
Originally Posted by tigerfan33 View Post
Kraine.
Lumens value at D65 low lampe : 717 lumens
High lampe : 939 lumens
post #43 of 798
From page 24 of the manual:
"The network is used to control this unit. It is not used for sending or receiving video signals."
From page 72 of the manual:
"The projector can be controlled by connecting it to a PC through the computer network with a LAN cable for control commands to be sent to the projector."
post #44 of 798
Are these calibrated lumens? If not, what mode were these measured in?
post #45 of 798
D65 means that they are calibrated. Actually the factory presets on my X35 are so good that I don't need to correct it :
Take a look here ;
http://www.cinetson.org/phpBB3/projecteurs-f2/jvc-dla-x35-successeur-x30-lunettes-test-cours-t36129-105.html
post #46 of 798
It's still there, but is it better than last year?
post #47 of 798
Yes by watching movies, ghosting effect is less obvious then the X30.
post #48 of 798
What is the differences between DLA-RS46 vs DLA-X35? I have an old epson 6500UB that is going to be 4 years old. It flickers like a mofo with a pinkish bottom screen. Time for a new toy?
Can you guys pm what the price I should be paying for this unit. TIA.
post #49 of 798
Take a look here ;
Which mode did you find more accurate, Cinema or Natural?
post #50 of 798
Both are accurate, but you have to choose the standard color space wich is close to the REC.709 reference.
post #51 of 798
Same projector
post #52 of 798
The Sony HW50 and Epson 5020 looks the same on the L/R patterns, the only projectors that can nail this test to perfection are the 3D DLP's.
The L/R patterns should not be used a sole indicator of ghosting performance. With real content, the HW50 and 5020 perform much better than the L/R artifacts would indicate.
Scenes from Sammy's Adventure, Despicable Me, Happy Feet 2, etc should be used for reference in comparing the ghosting artifacts. We'll have those screen comparisons between the JVC, Epson and Sony as soon as the US JVC's arrive which should be shortly.
post #53 of 798
Thanks for posting that info
post #54 of 798
Originally Posted by blee0120 View Post
Same projector
Thank you. What is the warranty for these unit?
post #55 of 798
Thanks Kraine.
Nice and bright;)
My Benq 7000 is a tad over 1000 lumens normal lamp. Not much difference.
Now the supposedly lamp fix has been done, no doubt a winner here!
post #56 of 798
The JVC projectors are already controllable over IP via an application. I am presently controlling my JVC-RS45 using an app called iRule on my iPad. Works great! JVC will just have their own app that does this.
post #57 of 798
Good to know, I've searched the App Store for an official JVC app, but it hasn't popped up yet.
post #58 of 798
Are the JVCs in general have flickering issue?
post #59 of 798
Hi Kraine,
How does this compare to any measurements you performed on the X30 previously?
I'm new to JVC PJ's and considering buying the X35, are you saying you select Standard colour space in the menu whilst in either picture mode setting?
post #60 of 798
46 will have a slightly higher lumen output than the 40 and 45. So slight that the human eye will not be able to tell much of a difference.
The BIG difference hopefully will be when the number of hours start clocking on the 46 it will be nice and bright compared to the same hours on the 40 and 45.
