AVS › AVS Forum › Video Components › Home Theater Computers › Problem WMC Through Remote Connection
post #1 of 11
I've been using Jump Desktop to connect to my HTPC on both my normal Windows desktop and my Android device. I mainly use it to schedule programs I forgot to add (e.g. football games), so I don't connect that often. The HTPC is running Win7, and the normal Windows desktop used to connect is running Win8.
Now I can connect, but I can't get WMC to run via the connection. When connected through my desktop I just get the message right away that WMC stopped working. When connecting through Android I get a message that the color resolution isn't high enough.
I've made two changes recently.
First, I installed Win8 on the desktop on which I connect through. I did that the first day Win8 was available, and I don't remember whether I've connected since then or not.
Second, I've changed displays on the HTPC to a 1080p display (before it was 1080i).
Since it won't start WMC using either Win8 or Android, I assume it's not related to Win8 being added to the normal desktop used to connect.
post #2 of 11
Does it start as an admin (right click "run as admin)? If that's the case, then you can lower the access rights for HKLM\SYSTEM\CurrentControlSet\Control\Terminal Server\WinStations\Rdp-Tcp (e.g. full access to authenticated users) to fix this.
post #3 of 11
I can't really answer your question, but why not just use the Ceton Companion App on your Android phone? It's much easier to just schedule missed recordings that way.
post #4 of 11
I'll give it a try.
post #5 of 11
I can't get port forwarding to work for that program. Reading through their forums, I suspect it's because I have two NICs, but their fixes don't work.
So that gets me back to the original question. Why can't I open WMC when connected?
post #6 of 11
Going from Windows 8 to Windows 7 (via Remote Connection) I have to run MC as Administrator.
post #7 of 11
Thanks, I'll try that.
post #8 of 11
You don't have to do that (see my previous post above)
post #9 of 11
I found the answer to this question on a few websites. Apparently a security update in about October caused the problem.
I found a solution here:
http://www.sevenforums.com/media-center/261036-remote-desktop-wmc-stopped-working.html
It involves going into the regedit, finding the registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Terminal Server\WinStations\Rdp-Tcp
and then setting permissions for "Users" to read the key.
It seems to work. Does anyone see a problem with having done that?
post #10 of 11
I think it was answered here in the second post and the one above yours...
post #11 of 11
Sure enough. I may have been distracted by trying the Centon app, although I don't remember getting it to work properly running as an administrator, so maybe I did that wrong and then never tried the fix.
