AVS › AVS Forum › Audio › DIY Speakers and Subs › DIY wiring question ?
post #1 of 6
I've made my own cables for my 2 subs that im building , is it a good idea to solder all of the ends of my cables ( instead of just leaving them on bare wire) , same for the end in the sub before they are conected to the voice coils.
....Simply put,.. Just leave wires bare or solder all ends ??
post #2 of 6
no need for solder if you have a good physical connection.
post #3 of 6
Thanks LTD , just thought they would oxidate without soldering ?
post #4 of 6
More likely with it.
post #5 of 6
Originally Posted by Bill Fitzmaurice View Post
More likely with it.[/quote
OK thanks guys
post #6 of 6
How are they connected now?
(I think you are asking about 'tinning' the wires with solder, rather than making a soldered connection. I agree that you probably should not tin the wires.)
-Max
