I'm desiring a bookshelf, two way speaker set up to replace my small Cambridge Minx speakers, and want one either in F Red or in high gloss white.
Sound quality is important so if imaging and sense of "being there" is good, then that is excellent.
I am looking to build a 3.1 or 2.1 system, as surround is "overkill" for the space I am renting out (a basement suite).
I am looking to spend $1000 or less, anything more is too much for me.
The speaker stands I am looking at are high gloss, heavy weight black ones (can't remember the brand), so I figure a glossy white or red (with black cones and tweeters) will look VERY nice paired with it.
If any of you have any recommendations it will be greatly appreciated. My walls are ivory, with beige/brownish carpets, and white cabinets, and a built in glass door/wooden cabinet.
P.S. Yes, I am shopping for speakers in a sense that they are furniture pieces as well, not just for function.
but they are great and great-looking speakers. You should take a listen/look.
