AVS › AVS Forum › Display Devices › 2.35:1 Constant Image Height Chat › Somfy control question
post #1 of 2
Hoping somebody could help me understand what I would need here. I'm just looking at using 2 somfy tube motors for automated side masking. Trying to stay as low cost as possible. 3 programmed stops would be fine. If I go with the IR version can I control both motors with one remote or do I need another controller? What's the advantage of the RTS versions?
Basically I just want remote control to operate both motors simultaneously with 2-3 programmed stops.
Would this work? http://www.avoutlet.com/index.php?dispatch=products.view&product_id=1444
post #2 of 2
Reposted this in DIY section
