AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Denon 2113CI vs Pioneer Elite VSX 60 vs Pioneer VSX 1122
post #1 of 3
I'm trying to select a receiver for my 5.1 home theatre and having a tough time deciding between the:
Denon 2113CI vs Pioneer Elite VSX 60 vs Pioneer VSX 1122.
I'm running Klipsch: rb61s L/R, RC62 centre and RS51s rear.
Also, what video scaler does the Denon utilise? Do the Pioneer Elite VSX 60 and Pioneer VSX 1122 both use the same Marvell Qdeo scaler?
Thank you for your help.
post #2 of 3
Any of them would likely serve you well, although the Denon is the only one that can EQ the subwoofer. It uses an Analog Devices 8003-3 video chip.
post #3 of 3
Thank you very much for the information. Do you know how the Analog Devices upscaler in the 2113CI compares to the Marvell in the Elite?
