I bought a PA-150 2 months ago that replaced a HTIB yamaha cheapo. Whent from 50rms 100 peak to the 15" pa 250rmw Bash amd and 1000 peak(if it really gets there.) I've been loving it, I didn't do calibration when I first got it I had an old Yamaha 371, so everything was manual, no SPL meter or any software used just a tape measure. After recently upgrading to the Denon 3312 and running Audyssey I realize I was way over "gaining/volume" my sub's knobs. After MultEQ XT I have a much flatter (imo) and more controlled base which I love. That said I must have really had it way over set because I would notice after 10 minutes of demoing my ears would start to notice it and actually maybe some pain. After calibrating, at first I thought I lost all my bass but that was due to me running hot (Going from a 6ish volume on the sub to 2.5ish setting to be within Audyssey's +-12 range). The bass I get now I love, but I'm missing the lower extension and I think that is my real problem. Also, I felt like the bass was non existent because the fact I was running way above a calibrated subs volume and I''m missing some lower extension, even if it was distorted.
The only tools I have is a power drill/driver as well as some stabilla levels. I think my next sub upgrade with be a DIY.
Goals in this order:
1) lowest frequency possible with usable output.
2) I want something I can feel, I can feel my current sub if I raise the volume on the sub after running Audyssey. I know I shouldn't be doing this, I also raise the -9db to about -1 or 0db to increase the output as well.
I say I don't listen to music, it will be done, but consider this a 100% HT setup. I'll probably start with one. Like I said before I have almost no tools, I don't think I can cut my own boards, So I'll either need a kit or a pre-assembled enclosure.
What I would like to know if I can get advice and direct links to DIY kits that I can buy all together or at least purchase known compatible parts and piece them. I'd prefer to buy a completed enclosure and not have to build it, this is last case scenario and I know I could save money here, thats the next project.
I need to know what DSP or calibration software I need for the new sub. I'm open to any suggestions, I'd prefer a cut and dry answer suggestion amp, enclosure, speakers. I like my Pa-15o, but I am shooting for my best opportunity to get non distorted lows at the loudest possible output without running my sub hot (maybe +2-4db after EQ) and never touching the volume on the sub itself.
Edited by clanmjc - 12/3/12 at 6:34am
As for completed enclosures or at least ones that are complete cut for me and all I have to do is assemble them, I'm up for the task I'll just need a few more materials and a bunch of clamps (I'll search more on those later).
