AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Help with 55 Lg 7600 . Best HDMI cables/3D cables etc
post #1 of 3
Hi,
I recently bought a 55" LG 7600. Compared to my old 42" Sony Bravia that I paid $3,000 for back in 2004 or so, I'm not very impressed. I'm thinking it may have to do with the cables I am using.
Does anyone have any recommendations on the best HDMI cables to buy along with 3D HDMI cables? Also, is it normal to have some serious backlight bleed in the corners? It's to the point where I can see it all the time no matter what is showing on the TV. For example, I can have CNN on and I will see light bleeding in the corners and edges.. Maybe I got a lemon? Or maybe I need to get used to the new standard.
I really appreciate the advice!
post #2 of 3
I've been happy with all the cables I have purchased from monoprice.
http://www.monoprice.com/products/search.asp?spcDB=10240&spcWord=Video+Cables+-+%3Cb%3EHDMI+%3C%2Fb%3E&keyword=hdmi
Use coupon code CATALOG12 to get additional 10% off is you decide to buy.
Edited by vrsixer - 12/3/12 at 2:00pm
post #3 of 3
Seems like you got a lemon.
As far as cables go as stated above monoprice is definitely a good place to get cables from.
