The Pi Speakers FAQ mentioned above has a section on multiple subs too. I think it's most worthwhile, because it not only describes Geddes method, but also the Welti procedure that preceded it. The "room modes" thread in that FAQ includes comments from Geddes back when he was refining his approach, so it gives historical perspective. It also shows my helper woofer or "flanking sub" approach, which can be used with either Welti or Geddes methods (or others). The flanking sub approach addresses the upper end of the modal range as well as the self-interference from nearest boundaries. So it smooths the upper midbass to lower midrange, where more distant distributed subs cannot because of localization problems.
On a related note, the FAQ also includes things like box construction, internal standing waves, crossover design and baffle step, and whether to use it or not. The baffle step discussion sort of segues from the multisub discussion, because multisubs and flanking subs are intended to smooth the modal range, below the schroeder frequency, where directivity becomes meaningless. Since baffle step is truly a directivity issue (that is sometimes treated with equalization or "response shaping"), one might wonder whether or not that even makes sense if the baffle step happens near the Schroeder frequency. This and many other things are covered in the Pi Speakers FAQ. So while it is primarily about horns and waveguide speakers, it's not just about horn and waveguide speakers.
Topics include:
General Information
- High-Fidelity Uniform-Directivity Loudspeakers
- Horn speaker design philosophies
- Various design philosophies
- Pi Cornerhorns - a brief history
- Fully Horn Loaded?
- Corner pi speakers
- Klipschorn vs seven Pi cornerhorn
- Notes for the DIYer
- Info to compare Pi models
- Options in a nutshell
- Upgrades
- Electro-mechanical properties and diaphragm motion
- Magnet structures
- Push-pull verses shorting rings
- Push/pull benefits
- Heat exchanger effectiveness
- Speaker Voice Coil Cooling System Valve
- Radiant Cooling System (Cooling Plug) Patent
- Hoffman's Iron Law
- Vented Speaker Systems
- Response curves of closed vs. vented systems
- Speaker damping - Overdamped, Underdamped or Critically Damped
- Acoustic filter Q and PiAlign's "Qe"
- Pi Alignments compared with B4, C4 and QB3
- Helmholtz formula
- Helmholtz frequency of each model
- Displacement calculations (or measurements)
- Cabinet design, port placement and internal standing waves
- Golden ratio for loudspeaker cabinets
- Trapezoid enclosures
- Damping material placement
- Altering dimensions
- 12Pi Basshorn Subwoofer
- Basshorn or Transmission Line
- Midrange Horn
- H290C Horn/Waveguide
- Horn phase
- Pattern control and mouth size
- Matching directivity in the vertical and the horizontal planes
- Speaker motors and passive crossover filters
- Crossover Electronics 101 Seminar Handout
- Phase angles, crossovers and baffle spacing
- Baffle spacing, phase angles and time alignment, revisited
- Tweeter circuits for constant directivity horns and waveguides
- Woofer size for uniform directivity loudspeakers
- Crossover configuration
- Baffle Step
- Constant directivity verses on-axis EQ for non-uniform directivity (aka baffle step filters)
- In-wall Baffle
- Floor Bounce
- Imaging, placement and orientation
- Speaker placement and wavefront launch
- Room modes, multisubs and flanking subs
- Helper Woofer Location
- Pi Speakers Measured Datasets
- Spice crossover models
- Determining mechanical reactance values for Spice models
- Clarification of attenuation values
- DI-matched two-way loudspeakers
- Crossover optimization for DI-matched two-way speakers
- Crossover optimization for DI-matched two-way speakers, revisited
- The Acoustic Center: How it applies to Loudspeaker Measurements
