Originally Posted by
mogorf
arnyk
Why would a parametric eq necessarily screw up the signal?
Always think of a parametric EQ as a frequency dependent volume control (invented in the 20th century, BTW), in this case 31 volume controls (not much).
You appear to be confused. An Eq with 31 volume controls would be a 1/3 graphic eq., not a parametric eq. The number of sections in a parametric eq is usually far smaller than 31, often only 3 to 6. Each section of a parametric eq has a frequency control, a bandwidth or Q control, and a depth/peaking or volume control.
How do you know which one to adjust and to what extent?
God gave me ears, fingers and a brain and the time to learn. ;-)
Without taking frequency response measurements in the room to see what need to be corrected it is nothing but guess work, not anything we could call scientific.
So what? Having the resources to do frequency response measurements is not rocket science in this day and age. I have all that at my disposal as well. So do a goodly number of the people posting to this thread, it seems.
The final result will be a room set to preference.
Which is far from a bad thing.
As an example the parametric EQ setting will most like result in a frequency response anything but flat.
Since you are obviously very confused about simple things like the difference between a graphic eq and a parametric eq, why should I believe such a excessively global statement?
Reality is that the problem of non-flat response is not a failing of either graphic or parametric equalizers as classes of devices, but rather a problem relating to the people making the adjustments. If the people making the adjustments have the right training and resources, they will be able to get reasonably flat response no matter which kind of equalizer they have.
Now you play an instrument that has a base frequency and lot of fundamentals (harmonics, 1st, 2nd, 3rd, etc.).
Heck, you don't even know which base is the right bass to use. You're going to lecture me about how to equalize an audio system?
With an uneven frequency resposne (sic) there is the likeliness (sic) that the ratio among the base(sic) frequency and all the harmonics will be changed, thus resulting in loss of fidelity, i.e. the instrument will sound differently than recorded in the studio.
That would hardly be a news flash. even if you weren't mangling the English spelling and syntax.
The aim of Audyssey is to EQ each speaker channel (and it's interaction with room acoustics) to a flat frequency response.
Of course. That's hardly a news flash.
Whether you know it or not, it is not written on stone tablets that everybody wants their audio system to have perfectly flat frequency response. My thinking was that if you had an equalizer and wanted to use it with Audyssey, one approach would be to let Audyssey do its thing unmolested, and then touch up system response with an independent eq to allow the listener to imprint his personal tastes on the system.
Thanks for trying to play, but...
