Originally Posted by
blueiedgod
I am too looking to expand the storage on the server. Bear with me, I am running Windows 2000 Server on a Pentium II 233 MHz, running RAID5.
Perhaps my mind is stuck in a traditional RAID where redundancy is achieved by writing in 2 locaitons.
If, for the simplicity of mathematics, I have 5x 3Tb drives, and I dedicate 4 of them to the pool, and 1 of them to the parity, then my pool should be 12 Tb, correct?
How is the parity achieved on the single 3 Tb drive? I just can't get over the notion that 12 Tb of data can squeezed into 3 Tb of space...
Should 1 of the 4 pooled drives fail, and I replace it with a blank, will FlexRAID rebuild the data in the pool using the 3 Tb parity drive?
Will the array be accessible during the rebuild (like RAID 5)?
Sorry for all the questions.
I would like to utilize my older IDE drives, which are all sub 500 Gb, which will push the drive count over 20, and UnRaid requires the "pro" license for the high drive count.
I will try at the above...
But I need to break it down so my ADD mind works properly.
blueiedgod
It's definitely a different concept that you can back up 15TB of data with 3TB of space.
blueiedgod
(5) 3TB drives with 4 as DATA drives (called DRU) and the remaining 3TB drive as a PPU (Parity drive) [back up]
So 4 data, one parity. Then you would have a pool size of 12TB. Yes. 4x3=12. 3TB Parity would provide backup if one of those drives went down. You could actually remove one of those drives and replace it with a blank 3TB drive and re-write the data back to it. Pretty cool if you ask me.
blueiedgod
Parity keeps track of the total - it's math.
remember that all digital information is stored as either a 0 or a 1. it's never anything different.
so basically it reads each unit across all the drives and records the sum on parity drive.
Look at this:
That is a good example.
It records the totals across your drives and stores the answer on the parity drive. That is why the parity drive must be as large as your largest drive so it can hold that many parity totals.
If you subtracted one of those data drives you could figure out what is missing or what digit the missing drive had. Just look at the digits you know... and the answer and you can figure out what it was. That is basically how flexraid works.
You can back up more than 5 drives. I use it on 8. But as you increase drive counts you increase the chance of simultaneous drive failures. That's a problem.
Last-
Yes.
Your "pool" is always available. Flexraid is real time. Once you set it up- your drive is always available unless your doing a rebuild. You can get an email each day on the status if you want to know it's ok. It can email you your parity is up to date and correct if you need to know or want to be sure. I don't bother.
also,
Flexraid will allow you to use your older drives. You can then replace them with larger drives in future. I am doing this. replacing a 500GB drive with a 3TB gains you 2.5TB of space without needing another SATA port or SATA power. It's the way to do it when you find $$$ and good deals on large drives. Plus- it's good to replace older drives before they fail. it's just easier.
