TV has worked good other than having to change lamp a couple times . The lamp popped a few days ago so I ordered a new one . Other than being a little dark the TV worked ok before replacing the lamp . While waiting for the new lamp I decided to clean the light engine mirrors etc. . I am 99.9% sure everything was reassembled correctly and after seeing the problem I double checked . The problem is when I turned the set on after replacing everything the picture is very very RED . Can anyone tell me if I did something wrong ? The screen also stays completely red after turning off for about 20 seconds . See on youtube http://www.youtube.com/watch?v=zBSVDQeQMsI&feature=youtu.be
AVS › AVS Forum › Display Devices › Rear Projection Units › MITS WD62530 RED picture After replacing Lamp
AVS Top Picks
post #2 of 6
12/4/12 at 4:04am
post #3 of 6
12/4/12 at 9:13pm
post #4 of 6
12/5/12 at 4:28am
post #6 of 6
12/5/12 at 2:55pm
AVS Top Picks
You will have to open it up to check all cable assemblies inside and re-seat any of those connections. This is under the assumption you are comfortable with this and basically know what you are doing. It's surely not the lamp, but by removing and inserting the replacement a bad connection might of developed.
