Hi,
as some of you might know, mpcclub.com forums became very unstable since its creator, Hi-Jack, stepped down a bit from the media player scene and let the forum "free of use". Due to massive spamming, the forum is getting more and more off line and I fear that this won't be solved shortly and might cause its death in a near future
In the past we already had this kind of things when the yadis templates were mostly posted with megaupload links. When megaupload closed, all the hard work made by some contributors was lost without any possibility to recover. As I don't want that to happen again for the international yadis community, I will make a cut/paste emergency thread to save everything that can be saved for the templates created recently for yadis 2.2.
I hope that the AVS community will welcome us, as we hope that this will benefit the yadis users on AVS that might never heard about mpcclub. I also hope that this is only temporary and that the yadis main section on mpcc will survive as well as the forum.
original thread is here (if you can still access) : http://www.mpcclub.com/forum/showthread.php?t=28388
I will add the contributor name to the template, if there's none it's because I did it
@Mods : this is a first emergency draft, i will resize the pictures if you think it's too big and taking too much BW...PM me if this is against any AVS rules.
This thread will contain only templates,
Rules for template contributors : no blabla, just include the name of your template, the yadis version it's compatible with and a link for download. that's all.
If someone has a problem with one template posted here, or wants to make any comment, please report to the other thread for support/suggestion here : http://www.mpcclub.com/forum/showthread.php?t=25852 (hope it's still working...)
It should be easier for users to track templates corresponding to their yadis version, based on the template's posting date related to any new yadis version release.
Let's start from yadis 2.2 ;-)
