AVS › AVS Forum › AVS Forum Information › Forum Operations Center › AVS logo missing?
AVS logo missing?
post #1 of 16
what happened to avs logo?
post #2 of 16
Huh?
Did you mean to include a screenshot or something else to go on?
post #3 of 16
I was surfin the web early this morning 4am - 6am.
The AVS logo in LH was missing, so I posted it here.
for whatever reason the webpage was not displaying it, so I wondered it there was a tweak to it, the graphic down,
Now, I see it's back there.........
post #4 of 16
Ok - it's a Firefox/MacOS issue.
AVS logo shows on:
Safari/MacOSX
Via my work Dell laptop:
AVS logo shows on
IE8/Windows
Firefox/Windows
Below image show that on my home iMac, along with that all my software is latest:
The bottom browser window is Firefox, the top one with logo is Safari.
Something in your AVS forum code is causing that?
Being a multi-use computer, I use Firefox and my wife Safari.....keeps the peace in our home, separate bookmarks/etc....
post #5 of 16
Was that in safe mode with all add-ons disabled?
post #6 of 16
No, I use Firefox and my MacOSX in normal mode...
all add ons always there...
post #7 of 16
Open if safe mode to rule out an add-on.
I have to think we have thousands of folks using FF on macs and we'd have many more reports of this.
post #8 of 16
Or it's just my OCD to notice and point this out, as it does not really affect forum usage at all.
Like I said, all was fine till yesterday.
Nothing changed my side.
Just AVS brand is missing....your call.
Sent from my 32GB iPhone4 using Tapatalk
post #9 of 16
Once you try in safe mode, that will tell us more.
post #10 of 16
Held down option key, restart FF in safe mode, AVS logo shows up....
post #11 of 16
post #12 of 16
Well - here they are, all std ones....I'll shut all down, re-start, my guess Like Steve Jobs "hated" it flash thats causing conflict....
post #13 of 16
Well, when I dis-able abblock plus 2.2.1 the AVS logo comes back.
When I enable abblock plus 2.2.1 the AVS logo is blocked....
That is the root cause, nothing else toggles it.
So, what ads are being streamed thru the AVS logo - or its related code??
My Safari has adblock 2.5.49, and it allows the AVS logo.
post #14 of 16
I have abblock plus 2.2.1 and it shows up fine.
You most likely blocked the image an never realized it.
post #15 of 16
ok -under the tools menu there is a menu selection for adblock plus.
I went to "report issue on this page", this came up
I diabled the filter, hit reload, and it now shows the AVS logo.
Again, I did NOTHING at all, this arose at weird 5am early hour as stated in my 1st post......
Not world peace, my OCD forced me to solve it though....
post #16 of 16
You (or someone with access to that device) most likely applied that filter at some point without knowing it.
  Back to Forum: Forum Operations Center
