AVS › AVS Forum › Audio › Speakers › Loud popping noises coming from speakers during Dark Knight Rises...
post #1 of 10
I put in Dark Knight rises and wanted to try it out at Reference level since I'm home alone for a few. Here is my set up.
PS3 for my bluray player
Yamaha rx-v765
XPA-3
HTD level 3 bookshelfs for L&R and Level 3 CC
Epik Empire
So I pop in the movie and during the opening hijack scene, I cranked it up to -10 as anything louder kinda scared me. At several points, I heard loud popping noises what seemed to come from my R & L. So then I turned it down and then tried it again, and again, loud popping noises. Less than -15 or so and it goes away. Any ideas?
post #2 of 10
Anyone?
post #3 of 10
Originally Posted by ratm View Post
Anyone?
are your speakers set to small so common bass is only from sub?
This will help from over loading main speakers.
Just a thought
Sent from my SGH-I747M using Tapatalk 2
post #4 of 10
I am pretty sure they are but I'll double check
post #5 of 10
Any ideas?
That popping is either the voice coils in your drivers bottoming out or the amp running out of headroom, or both. None of your speakers are really capable of running at reference with enough headroom to handle high level transients, so don't risk damaging them trying to do so.
post #6 of 10
Thank you Bill. It's Not like I listen that reference level anyways. So looks like -15 is as loud as I'll go.
post #7 of 10
Crossover settings? I would try different xovers, but for higher output I would try 100-120hrz and see if that solves the problem. I had a similar problem with some bookshelfs and switched to towers and my problems was solved, much more headroom with a multi driver tower or large monitor.
It could be the ribbon tweeter too, I've heard some say that ribbon can make some really strange scary sounds when pushed pass there limit.
post #8 of 10
Someone over at audioholics mentioned the same thing. I had it at 80hz and have since raised it to 100. I wont be able to try it out again until tomorrow. As an aside, I didnt think I would encounter that problem with an XPA reaching its limits at less than reference with my AVR.
post #9 of 10
I don't think its the XPA causing any issue, its just the bookshelf isn't capable of that output crossed at 80hrz. The XPA can run much more power hungry speakers than those HTDs so I really doubt the XPA is at fault.
post #10 of 10
Might be, although Santa is bringing me a bunch of jiu jitsu crap so he might not be able to spring for $800 speakers. And thanks for all the responses. I changed the crossover to 100hz from 80. That was the first (and probably) last time I tried to play it that loud. Looks like from now on, Im not going louder than 15-10 or so. At 11 feet, -15 is plenty loud for me.
  Back to Forum: Speakers
