AVS › AVS Forum › Audio › 2 Channel Audio › Pro-Ject Carbon - acrylic platter, or mat?
Pro-Ject Carbon - acrylic platter, or mat? - Page 2
post #31 of 46
Originally Posted by ckcoolic View Post
I suspect it might have to do with the greater mass of the steel platter.
Yes, I think you might be right about that...I think I read someone else theorizing that, and it makes sense.
I have heard people postulate that the steel platter could have negative interactions with moving magnet cartridges, but it was only supposition with no data
Yeah, I heard that too, I think that's a red herring. Seems to me that presupposes that no one that knows anything about manufacturing turntables ever used steel in their platters before, or bothered to test for any interaction. I suppose it's possible, but I'm guessing that the relative power of the magnet in the cartridge is actually so low that it's a non-issue. But I could be wrong.
Already have my acrylic platter now though, I'll live with my increased THD+N in order to have the good looks.
Interesting you say that - what color is your base? I got the Piano Black, and I like the "all-black" look - I thought the white acrylic patter would disrupt that and was wishing the platter came in black.
- Mark
post #32 of 46
From what I have read it is a Moving Coil cartridge that has issues with a steel platter, due to the very strong magnets used in the moving coil design.
post #33 of 46
Hum is almost always caused by poor ground connections between thew cart body and the preamp. Also some carts ground the body to the left channel ground pin (Shure) and others like Grado don't. Hum in the latter group is more common. And as the cart tracks closer to the motor the louder the hum. Also it's very rarely an issue w/MC carts even LOMC carts. Also considering the type of low mass tonearms you have on these TT's MC carts would be a very poor match. You have to look at basic tonearm compliance to get the best sound out of your TT. In the case of this TT something like a 2M Blue or or similar would get the max out of this model.smile.gif
post #34 of 46
Grado cartridges will hum badly with some turntables because they are not grounded.
I ordered one for my Music Hall MMF-2.2 and had to return it. There is no way to eliminate the problem according to Music Direct, where I bought it.
post #35 of 46
Originally Posted by Martycool007 View Post
With regards to an entry level turntable, such ss a Pro-Ject Debut III, or a similar $400 dollar turntable from someone else, do most of you guys feel that the platter is always the first thing that should be upgraded when starting to tweak/add/upgrade these turntables?
if i could go back, i would have checked out some local dealers that had TT that were trade-ins or demos that list for $1k so i could have picked one up for $600. which is about where Im at in what Ive spent on my TT.
post #36 of 46
How do you think the Sumiko Pearl will perform vs. the stock Ortofon 2M Red? I picked up the Pearl for my last TT but upon installing it realized the TT itself was on the fritz, so never really used it. (callas01, I see that is your cartridge as well).
I'd like to mention to Martycool007, I'd also recommend buying the best phono preamp you can swing, which will improve any TT. Back when I was a bit more flush, I picked up a used Thorsten modified EAR 834P - when I A-B'd it with a Pro-Ject $200 preamp, the difference was astonishing. It even made my old Yamaha YP-450 (with a Sumiko Black Pearl cartridge) sound pretty good.
- Mark
post #37 of 46
I'd like to mention to Martycool007, I'd also recommend buying the best phono preamp you can swing, which will improve any TT. Back when I was a bit more flush, I picked up a used Thorsten modified EAR 834P - when I A-B'd it with a Pro-Ject $200 preamp, the difference was astonishing. It even made my old Yamaha YP-450 (with a Sumiko Black Pearl cartridge) sound pretty good. It depends on what you like. The Ortofons have better detail at the top end while the Sumiko will give you a warmer mid range. In my case w/Aerial 6 speakers which a rolled off at the top end the Ortofon 2M Blue proved to be a better match for my system.smile.gif
- Mark
post #38 of 46
- Mark
I read somewhere once that the 2M Red was really similar to the stock OM5E that came on the Debut III, so I decided I would try something other then the 2M RED, which is the one that I was thinking I would go with. The Pearl is a little bit boomy, but overall its a decent cartridge for the price. when you first get it going its really boomy, but it tightens up a little bit and settles in for a decent long term cart. I think the next cart Id go for might be either the Clearaudio Concept MM cart or one of the Grado wood carts.
post #39 of 46
So you guys recommend upgrading the phono pre-amp first? Right now I am currently using a Denon AVR-3312 to power my 2 channel system concurrently with my 5.1 surround setup. Do you guys think I should spring for some thing like a NAD intergraded amp and then look for a new phono pre-amp? Basically what I am trying to figure out is if my Denon AVR-3312 is a suitable platform to run a turntable off of?
post #40 of 46
What preamp are you using now? What turntable are you using now? Cartridge? Perhaps it would be better to start your own thread, and explain your situation fully, rather than hijack someone else's.
In any case, buying an integrated amp that doesn't even have a phono input makes no sense at all. If you must, just upgrade your phono preamp.
post #41 of 46
I would not want a phono pre-amp built into my IA, I like experimenting with phono stages, right now I have a Bellari VP130 in place of the v-lps and its a much better phono then the v-lps or the pro-ject phono or rega phono. Its like buying a dac thats built into my IA, not something Im interested in having either.
post #42 of 46
out of curiousity... which Pro-Ject phono pre did you have?
post #43 of 46
I have a Herbie matt on my Well Tempered and absolutely love it. Prior to this I made my own because I didn't like the sound of anything else out there. My brother and I both use many of Herbie's accessories - they work.
post #44 of 46
I have to say it all depends how your listening to your vinyl and what your listening for, your environment and other gear. For me it's one of the things I do regularly on a daily basis. I listen to a wide range of music, from Jazz, Soul, Funk and Rock and Roll. Adding the platter upgrade is a solid move. It defined the musicality of all my records. The quality is subtle but isn't that what true listening is? The response from my records was clear, it was a richer and sonically better all around. For a total of $528.00 the turntable and platter wasn't out of line for the quality and sound that you get. I run an NAD 317, Pro-Ject Phono Box II Pre-amp, along with the Pro-Ject Debut Carbon with the stock Ortofon 2M Red cartridge through a set of Paradigm 5SE speakers.
post #45 of 46
Hi,
I read a previous post of someone saying these tables are not worth upgrading, and i must say that is ridiculous given that these tables are for people just getting into turntables. This table is a good price for the very reason that it does not have the high quality parts of other turntables, which can be purchased as upgrades to improve the sound.
Personally i feel your speakers and amplifiers are top priority for sound, proper turntable setup, and keeping your vinyl as clean as possible. However i have made upgrades to the Debut III and the 3 most important for me was the Audio Technica AT120E/T cartridge for better frequency response, cork/rubber mat for less static, and a record weight of at least 300 grams. The record weight in my opinion was the best upgrade because it stabalizes the record which added a lot of sonic clarity to the highs and definately more punch to the bass. The three of these will run about 250$ and i have personally tried the acrylic platter and it was not worth the price imo.
I bought a new Rega RP3 and my upgraded Debut III sounds every bit compable when playing the Hi-fi News Analogue Test LP.
post #46 of 46
Hi all. I got a Project Carbon + Phono Box S - MM/MC phono preamplifier pushed by a Wired for Sound STI500 integrated + W4S DAC 1 upgraded + Elac BS244 speakers. Im wondering to do some upgrade for my TT. Do you guys think the acrylic platter is a decent upgrade or not so much difference from the stock platter one?
Ricardo
