I have a 4810 on preorder from AVS. I have a treated room and am using 145" 2:35 1.3 gain screen. I will likely keep this projector for several years. The big question is the upgrade to either of the more expensive projectors worth it assuming all are in my budget range? I have to decide during preorder period or they WILL NOT be in my budget range.
Thanks for any feedback.
S
S
