AVS › AVS Forum › Audio › Audio theory, Setup and Chat › What is your preferred option for converting 5.1 to 7.1 with Surround Back?
post #1 of 8
I recently bought an Onkyo TX-NR818 and wonder what the preferred option for converting 5.1 to 7.1 with Surround Back is. My receiver does Dolby Pro Logic IIx, DTS Neo:X, THX Select2 Cinema, and THX Surround EX for accomplishing this. It may have other modes that I have not found. My receiver also does Audyssey DSX, but I think that only adds Front Wide and Front Height speakers, and not Surround Back speakers.
Btw, I would like the settings for watching movies.
Thanks a lot for any help.
post #2 of 8
Those two THX modes extract a mono surround-back channel from the surround channels, sending the same content to both rear speakers. By comparison, PLIIx and Neo:X extract stereo surround-back channels, so the rear speakers contain independent info rather than being run in dual-mono.
With that in mind, my preferred option is for PLIIx and Neo:X instead of the THX modes. Of the two preferred options, I don't find much difference when using them to scale 5.1 channels to 7.1 speakers. I would lean towards PLIIx because the stereo separation in the rear speakers is a little more distinct.
post #3 of 8
I use PLIIX for the reasons stated above.
post #4 of 8
Will PLIIx or Neo:X degrade lossless TrueHD, DTS HD MA, or PCM tracks, or will they simply steer the lossless audio to the Surround Back speakers?
post #5 of 8
I've set PL Iix 2 years ago and it truly enhances the 5.1 into 7.1 quite well.
Sent from my 32GB iPhone4 using Tapatalk
post #6 of 8
Another vote for PLIIx.
Cheers,
post #7 of 8
Hi, I have the same AVR running 9.2 with rears and heights and I finally settled on NEO X:)
post #8 of 8
The latter. Lossless audio doesn't stop being lossless when you apply bass management, time alignment, surround processing, room correction, etc.
