I'm not sure if this is the right forum for this, but it seemed to be mainly a PC issue:
Given I have an old laptop with a Firewire port,
And I have a DVD recorder with a Firewire input port, (Magnavox, but if I thought the model mattered I wouldn't have posted this here)
If I get a cheap 4-pin to 4-pin Firewire cable,
Then is there some free or very cheap software I could use to stream generic videos from the PC to the DVD recorder?
I found a similar thread from 2004 (one year older than my laptop) but it seemed to need a $150 card. This is a laptop, and I wouldn't spend more than the cost of a VGA to composite converter on this. (Which appears to be $20.)
TIA!
TIA!
