Originally Posted by
cyeingst
Are the shelves adjustable on the Becton ?
Could you provide the dimensions of the shelves...........Thanks
The two side compartments are only 14 inches wide and 15 high maybe an cable box, Xbox or Playstation will work there but plenty of space for movies an such, the center compartment is 32 inches wide and all shelves are adjustable and hold up to 50lbs, if your looking to store all your gear this stand may be a no go if you have a large center as well, but if like me you wanted a stand low enough with good looks and ample space for a center channel this cant be beat:)
