AVS › AVS Forum › Video Components › Home Theater Computers › Is this a EDID problem?
post #1 of 3
My htpc is connected with hdmi to my pio 1021 amp ----> panny vt25. The htpc is on 24/7.
I have my harmony setup this way
TV
Amp
switch amp to htpc
live tv button
When this works which is the majority of the time its just like a cable box... family approved!
However sometimes when starting up, WMC would be in 4:3 mode (black bars on the sides) and the only fix would be to close wmc and open it again.
Any advice?
post #2 of 3
Since your TV should have enough inputs, how about using the TV to switch then output audio to the amp.
post #3 of 3
what about the hi-res audio? optical wont pass those formats. i'll try messing around the the harmony settings, maybe add couple delays between the tv and amp.
