AVS › AVS Forum › Audio › Speakers › Def Tech 2 Channel Bedroom Setup Assistance
post #1 of 8
Hi everyone - Happy Holidays
Haven't been on AVS in ages; seems like things are getting better and better.
I'm attempting to run a small/ budget 2 channel setup in my bedroom for occasional use. I'm re-purposing a "vintage" set of Definitive Technology Gems for this task. Being small bookshelf speakers, of course they are missing a bit of bottom-end.
My setup is as follows:
"Vintage" Def Tech Gems (on stands)
Apple TV2 (soon to be replaced by a Nettop/ HTPC)
Emotiva XDA-1 - DAC
Emotiva UPA-2 200 Watt Amplifier
I'm not a huge "bass-head" and my music taste run the gamut. Would a Supercube give me the bottom end I need without being too overwhelming? Maybe something from the ProSeries? I've been scouring E-bay and Amazon for deals around the $350 mark
Another potentially silly question, but would staying with the same speaker manufacturer (Def Tech) offer any real benefit?
Thanks everyone for your assistance... as I'm stuck!
post #2 of 8
No need to stick with DefTech.
What you should make sure is that you get a sub with dual RCA in-and-out and that has a high-pass filter on the OUTs. That way you can run cables from the DAC/pre to the sub and then from the HPF-outs on the sub to the amp and have proper bass management.
post #3 of 8
Thanks! Yes, the XDA-1 is connected to the UPA-2 with XLR to RCA cables. This leaves the other unused RCA connectors on the XDA-1 available to connect to a powered subwoofer.
post #4 of 8
You don't want to do that - that way you are sending full range to the amp.
Just connect the DAC to the sub, and then the sub to the amp - that way you get proper bass management (using the HPF in the sub).
The alternative would be to do as you suggest, but add a high-pass filer to the end of the XLR-to-RCA cables. If you go this route, look into Harrison Labs FMODs
http://store.hlabs.com/pk4/store.pl?section=9
Edited by rick240 - 12/5/12 at 10:10am
post #5 of 8
Thanks Rick, would a Polk PSW10 do the trick?
http://www.amazon.com/Polk-Audio-10-Inch-Monitor-Subwoofer/dp/B0002KVQBA/ref=lh_ni_t
Obviously the price is right, but would it offer the tight, smooth bass that would best suited for music?
post #6 of 8
I wouldn't get the PSW10. It's just not worth it. I would check out the budget subwoofers thread in the subwoofers forum for better options.
post #7 of 8
Also, consider used:
- from craigslist LA:
Velodyne DLS-4000R for $325
Velodyne SPL-1000 for $400
- from Audiogon
Velodyne Impact 10 new for $230 plus ship from CO
PSB Subsonic 5i for $150 plus ship from NY
NHT Model 10 for $110 pickup in Roseville
Just some ideas.
Might find a demo at a local store.
post #8 of 8
Thanks everyone.. now for argument sake, would it be possible to stay in my same budget ($350), purchase a nice set of full range speakers and achieve the same fullness I desire? This would not involve the Def Tech gems or a subwoofer....
  Back to Forum: Speakers
