AVS › AVS Forum › HDTV › Local HDTV Info and Reception › Need Advice on Picking out an Antenna in Southeast Kentucky
post #1 of 3
I live in southeast Kentucky right on the Virginia line in Smith Kentucky its very mountainous. I have used a small $30 lava hd antenna for the past year or so and can pick up WBIR 10 from Knoxville and WJHL 11 from Johnson City. My question is, if I buy a bigger or more powerful antenna or mount it higher could I recieve the other stations from Knoxville or the Tri Cities or maybe even WLOS 13 from Asheville NC?
post #2 of 3
A better antenna would definitely help. Consider Winegard 7698 or Antennacraft HBU55. And a good preamp possibly.
post #3 of 3
Go to tvfool.com and get the results using your address then post it here(your address will not show).Then someone will be able to help you.
