Thanks for the tip... Will definitely take your advise. Wife probably is not the friend I should use then. She is patient but we don't always work so well together with things like this.
I did not plan so well though. I just ordered my 138" Stewart Deluxe screen... has not even got here yet. Hind site I should have just bought the luxas screen. Mike tried to tell me that. I would have saved a little money and now I have to shim the Masquerade to fit around the screen.
Plus I'd have to then adjust the zoom and focus using the remote, so more messing about. As my room is far from perfect not seeing the side panels light up in brighter scenes really helps improve the perceived contrast too.
