Hi all. I need some help. I want to set up a dedicated network mostly for music and audio sharing but I do not know the first thing about it.
I've researched a bunch of stuff on here but nothing definitive on how to accomplish what I'm trying to do.
Basically I have a Denon AVR 1613 receiver which my cable and ps3 are attached to and it feeds my LG 60LM7200. I want to create an audio network that my Receiver can access and share all my music through so my laptops, ipads, iphones, and receiver can all pull the same music. Additionally I'd like to be able to use the remote app that comes with the Denon on my iPhone but in order to do that it has to all be networked in together. I have a dell PC which I can dedicate as a storage device and I also have a seagate external hard drive I'm not sure if I could also potentially use.
I have a basic Belkin wireless router which is attached to my modem. It is on a different floor than my receiver. Is there a wireless reicever which can receiver the signal and then Ethernet hard wire into my receiver or do I need to relocate the modem & wireless router combo to be where the receiver is and hard wire into it?
Also is there a softwear I can download on my PC which will just make it an audio/file storage device on a network? Or do I just need to set up a shared drive on the PC?
Once again any and all help would be appreciate. I'm a complete neeeewber when it comes to networking and ultimately my end goal is just to have my receiver and iDevices all be able to access music from a central location.
Thanks in advance to any and all advice. Once again I assume I will have to replace/add other components to this to make it work, so any recommendations would be appreciated.
