AVS › AVS Forum › Audio › Audio theory, Setup and Chat › Setting up new 5.1 speakers with 14 AWG speaker wire and noticed the instructions for the speakers says to use 16-20 gauge wire. Will it hurt anything to use the 14?
Setting up new 5.1 speakers with 14 AWG speaker wire and noticed the instructions for the...
post #1 of 5
The speakers are Klipsch HD Theater 1000 5.1 and they are being connected to a Denon AVR-1613 receiver if that matters. Thanks in advance!
post #2 of 5
Your intro above there got cut off.
14 gauge wire is the right thing to use.
Is there some other question?
post #3 of 5
Oops. The issue is that the instructions that came with the speakers say to use 16-20 gauge wire. I have 14. Is it a problem to use the 14 when it says to use 16-20? From I've been able to gather it shouldn't really matter and should improve quality if anything. Can you confirm? Thanks.
post #4 of 5
Only if the terminals won't accommodate 14. If it fits in the holes, you're good.
post #5 of 5
Thank you!
