Hey guys,
Hopefully this is the right place to post. I'm not looking for you guys to find something for me, but I'm looking for help on HOW to find it.
Here's my situation:
I'm trying to assemble a little bit of a home theatre system (for the first time) in a new house, and I've just purchased all the components. The issue now, however, is where to put them. I'd need a place for a receiver, subwoofer, set top box, xbox, and similar things. I have a corner in which to put them all, but I'm having a LOT of trouble finding a unit that will fit in there. I know I could go the custom shelving route, but the quotes that I've seen so far are about $500, and I'm hoping to save a bit of money . Also, I'd do it myself, but I'm not that handy.
So, here's the room:
(pardon the mess)
So, as you can see, the coax is fed from the back wall, and I have a hole in the drywall beside the fireplace feeding my HDMI cable to my TV. That table would be gone. I'm looking for a shelving unit (or TV stand) that will fit in that gap. It needs to have accessibility for the cables behind.
Here's the issue:
I need it to be 15" deep (or less), 39.5" wide, and less than 48" high.
I've looked EVERYWHERE - ebay, amazon, kijiji (I'm in Canada), bestbuy, furniture stores, electronics stores. The stuff I've found that fits the bill are usually TV stands, but they're mostly 42" wide, which is slightly too big. I need to find a way to google for units by dimensions or something. Does anyone have any idea how I can search for stuff like this, or perhaps, what kind of item I should be looking for. I've been searching as "entertainment units", "tv stands", "audio stands", "audio racks", "entertainment stands", etc.
Any help would be very much appreciated.
(pardon the mess)
Here's the issue:
