AVS › AVS Forum › Audio › Audio theory, Setup and Chat › Multi sub setup with audyssey.
post #1 of 4
I tried in the subwoofer section but didn't get much response so figured I would give it a shot here. AVR-3310CI, 2 crown amps, Behringer dual 31 band EQ, 2 18s and 2 15s. Trying to figure out the best way to set my system up properly. I have the sub output split and going to each channel of the behringer EQ. Each EQ output is split and goes to its own Crown amp which powers a pair of subs. I figure there is no way for Audyssey to properly handle this so what I've done so far is set up my DB meter, pick a target DB of 95, and play test tones while adjusting the EQ to archive as close to 95 at each frequency I can get. I did it once with just the 18s powered and once again with just the 15s powered. My plan is to now run Audyssey and see what it does but I am very open to suggestions or even a blatant "hey dumbass, do it like this". The system sounds great but I have the equipment so I figure I may as well make it as good as possible.
post #2 of 4
I posted in your other thread.
post #3 of 4
I'm running four budget subwoofers in my rather small HT.
I have a Onkyo TX-NR3009 receiver with Audyssey MultEQ XT32 with Sub EQ HT.
I leveled each sub individually to 80dB, prior to running the full eight position Audyssey calibration.
My subwoofers include two ported and two sealed models.
Audyssey did a magnificent job of blending all four subwoofers seamlessly.
The bass is clean, tight, powerful and oh so smooth over all the seating positions.
post #4 of 4
Your signature says you have the following subs:
SVS PB12-NSD Subwoofer x 2
BIC America F12 Subwoofer x 2
Here is the SVS PB12 NSD:
Here's the BIC F12:
I see ports on both those subs. Which one is the "sealed" sub?
Craig
