I was tasked with building a theater in our winery's "ballroom" with a budget of only $15,000. I built three of Wayne Parham's upgraded 4pi speakers for the mains, and twelve of his 1pi speakers for the surrounds. I built four F20 horn subs (thanks lilmike) using Daytona's Reference HF driver. It is designed to be a 7.2 system. Today I installed a Center Stage XD screen from SeymourAV over a 30" deep baffle wall that contains the mains and the subs. The screen has an advertised gain of 1.2. Right now, the screen is 168" x 100", but will be getting a 5.5" velvet border that will alter these dimensions to 157" x 89", or ~ 180" measured diagonally (see below).
I originally budgeted $5,000 for the projector, but having gone over budget on the audio portion, need to scale that back to $4,000. The room is 45" long and 30" wide. The rear of the space has a balcony that is also 15' deep. The area that does not have a balcony has 19' ceilings, the space under the balcony has 8' ceilings, and the area above the balcony has 9' ceilings. Overall, the room has volume of about 20,000 cubic feet. There are many glass doors and windows in the space that allows a lot of natural light in. I plan to have heavy drapes on the windows and doors, but the projector needs to do well in all lighting environments...probably in the 4,000+ lumen range.
I have been looking at the BenQ SH960 and the BenQ SP891, but am needing feedback on what projector might best fit our needs at that $4,000 price point. I should note that the projector will be mounted under the rear balcony at 27' from the screen.
My build thread is located here: http://www.avsforum.com/t/1342983/building-a-dinner-theater-w-diy-speakers-subs-etc
Edited by dutchswan0311 - 12/5/12 at 6:53pm
