AVS › AVS Forum › Video Components › Home Theater Computers › Mediabrowser - no audio in m4a files
post #1 of 3
Hi, i have some music that I had previously downloaded from itunes in m4p (protected) format. I used the store to redownload the music in m4a format. mediabrowser sees it ust fine (it didn't see the m4p files) but when i play it, it has no volume. Is there something else I have to do to be able to use the songs i bought from apple in mediabrowser?
thanks
post #2 of 3
Also - the songs play fine in itunes
post #3 of 3
First off, don't buy songs from apple.
But if you already did that do you have the right codecs installed?
