AVS › AVS Forum › A/V Control & Automation › Home A/V Distribution › hook up to pioneer vsx 50
post #1 of 4
I'm hoping someone can help me here as I'm trying to figure out something but can't find answers
i have a pioneer vsx 50 , with the output going to a projector (hd20)
i have a pc hooked up to one of my inputs via HDMI ( so it plays video and audio through my speakers out of my receiver and video to the projector)
I'm trying to run a karaoke/dj program out of the pc ( virtual dj) which plays fine audio and video ..
my problem is adding a microphone to the equation
i have contacted the virtual dj forums but they keep saying to hook up an external set of speakers which i don't want to do
my question is , is there a way to have the video from the pc input play on the screen and then simultaneously play audio from another source through the recieveer i.e. zone 2 ?
I'm thinking in theory i can have the pc input show the screen and then play sound via rca cable to the zone 2 ...will that work ?
hopefully i made sense and didn't confuse anyone as much as i am lol
post #2 of 4
Did you try hooking up the microphone to the PC? You need a mixer to blend the audio and the microphone - if you're using a karaoke software package, I'd assume it would have the functionality already included (although your PC should be able to do it on its own) - so the mixed music + voice would come out the HDMI output...
post #3 of 4
so you mean run my karaoke program i.e. virtual dj for the video/songs
and then use the internal control for the mic and the sound will work for both ?
post #4 of 4
That would be the first thing to try, as it's free!
  Back to Forum: Home A/V Distribution
