AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › IPS Panasonic screen
post #1 of 10
I am not sure if all IPS screens are driven this sort of way or not.
I get like very very faint lines going down the screen ( its not the backlight as it sometimes shows on dark/ colours )
I don't think it's a fault I think it's how it's driven somehow can anyone explain?
post #2 of 10
Im not sure what you are describing, but it sound like it could be banding. Search "LCD banding."
post #3 of 10
It's not banding it's like down the screen there's very faint line not light. It's weird. But the backlight is even no problems what so ever!
post #4 of 10
Now it sounds even more like banding. Is it more visible during a panning scene?
post #5 of 10
It can be still or moving. But the backlight is even and does not have any clouding issues or anything like that!
post #6 of 10
I think I am being picky that is all because I have looked at the LCD banding pictures and its not like that. I am only seeing it on bf3 and forza. Could even be how the games made because I am not just seeing it in a certain area smile.gif
post #7 of 10
Could be an HDMI cable or HDMI input issue. Try switching the cable to another input and if that does nothing try a different cable.
post #8 of 10
In my case it was the cable. (LG 65LW6500, IPS panel).
The OP's problem sounds very similar to one I had recently, except it was just a couple vertical lines, very visible. They appeared only after playing a solitaire game for a while from my HTPC. Start a new game and bam, there they were. Had to cycle the TV off and on to get rid of them.
A new monoprice HDMI cable fixed it. Worth a try.
post #9 of 10
Will try a new Hdmi cable smile.gif thanks.
post #10 of 10
When I change preset to normal picture it's fine but when I change it to game picture it has the lines? Very strange! Can't use normal preset due to lag!
