Originally Posted by
robertcharlesÂ
Question? What amp is powering the Jbl's. And also, pre amp. Is the voltage enough to drive the amp. I had that issue with the pre amp I was using a while back. I needed to add something to step up the input and voila, it worked. Just kicking out ideas.
I am using two ep2500's for the jbl's . One bridged per pair .The preamp is the denon 4311, I have used it with like 5 different amps, never a problem with not enough voltage. Lately I have been using the opening seen of immortals to test the lfe. I also found a sweet game for 360 that has some nice bass, its called sniper elite v2, if you like shooting games, check it out. N8 , looking good , let us know how you like them.
