I have done a bit of research on FlexRaid and from what I could gather is that it works with the data rather than at the drive or file system level. So its way more reliable than any other form of RAID and chance of losing data is minimal with OS crash or component failure. Even accidental deletions or data corruptions can be remedied since you need to manually update the RAID parity. So as long as you notice the problem before updating the snapshot, the parity drive can act as a backup and restore the original data.
I am currently implementing a typical backup everything to external drive scheme. But its getting expensive having to buy 2 drives at a time everytime I run out of drive space. Can I simply get rid of all of my backups and instead designate a couple of external hard drives for parity? The externals will be disconnected after the parity is updated. The main data will reside in the internal HDDs. Will this be as reliable as my current 1:1 backup scheme or is there a catch?
) I like the convenience of having all my data centralized and I also realize that this creates risk. My solution mitigates this risk while still retaining functionality.
