AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Audiophile grade stereo Solid State amp under 100 for vacuum pre amp
post #1 of 2
Hello people, I have a quick question.
I need a solid state amp to go with my vacuum tube pre amp for under 100. I don't care if it's DIY, or ready to purchase. I have sufficient knowledge to make kits, but not pick parts + build from scratch.
If I can upgrade/mod parts to achieve higher grade sound quality, I'm willing to do that. ( ie using higher capacity caps or better transformer).
My preamp is $70 no-name kit that i bought from eBay years ago, I don't remember the model# but It's using Amperax 6922 tubes.
I'll be using homemade stereo (full range) speakers that's rated @ 4ohm, 30watts. Obviously, it's a small speaker (4") so you don't need to pump out a lot of juice into these delicate things.
post #2 of 2
bump
