AVS › AVS Forum › Audio › DIY Speakers and Subs › Need more extension
Need more extension
post #1 of 12
So a couple of years back I built this TH
http://www.avsforum.com/t/1240371/high-output-8-tapped-horn
it doesn't break any windows or belt out huge spl but it certainly delivers good performance for its size and cost. I want to go deeper though but I'm pretty size limited. The max dimensions are 48"x15x30.
Is there any good designs out there currently that would get me down to say 18hz at 105db or 100db? Can't go sealed.
post #2 of 12
Side firing, ported Dayton HO18 ?
post #3 of 12
How bout a sonosub? It would fit the footprint and provide exactly what you are looking for.
post #4 of 12
I like this idea and never considered a side firing sub.
If I go with a slot port like the easy button, figure 2" tall and 13.5 wide the port length would be about 91.5" and the chamber is around 7-8cuft. Hitting it with a 500 watt bash amp where would I hit the X-max? I may be able to build this on two sheets.
I can never get my models to work for some darn reason in winisd.
post #5 of 12
Been playing around with winisd, mdeling with a bash 500w amp and the dayton 18" and the SI 18"
Course then I remembered I have two unused 18" maelstroms in my basement and put that in the model with an ep2500 and 2kw
Am I missing something, the box has a driver depth dimension of about 13.5". I can build it in two sheets doubling up the baffle or possibly one sheet with one baffle.
post #6 of 12
So no comments?
After looking at some numbers and seeing what I would have to buy I think I am going to go with the SI 18" and a 550 watt dayton plate amp, box is about 10cuft and a 27.25x12.5 port length. I'm going to need two sheets for this.
I think I may sell my two sealed mael-x's in their own cubes.
post #7 of 12
Originally Posted by stgdz View Post
So no comments?
Why cant you go sealed?
What about a giant LLT box.
2 maels in a sealed box would be pretty good on the low end, imo.
post #8 of 12
Can't go sealed
https://www.dropbox.com/s/2r2z77loxq7as6i/2012-11-29%2021.51.05.jpg
I have to deal with what I have and those dimensions are the largest I can go. I've pretty much tossed out the idea of sealed since I need output.
post #9 of 12
Quad HO-18 dual-opposed would just fit into a 37x18.5x18.5, the bigger the better.
Model that, see what you get...
post #10 of 12
Do you guys even read what I type?
post #11 of 12
Yes, but: Why are you restricted to those parameters to such a degree?
One of this: http://www.data-bass.com/data?page=system&id=3&mset=35
In one of this: 48x15x30
and one of this: http://www.crestaudio.com/products/browse.cfm/action/detail/item/116972/number/03513840/cat/342/CC%205500.cfm
105db @ 18hz or better, in 2-PI space no less.
post #12 of 12
plus I have 4 maelstroms in the basement and I have to keep the boss happy, she's a bit unhappy with 85db at 60hz so I don't need to go full reference level in my critical viewing area.
Edited by stgdz - 12/16/12 at 9:35pm
