I am designing a sub enclosure to go under the back seat of a truck for a friend. I need the help of you guys more familiar with car sub design. There are two variables which I need advice. Subwoofer driver choice and Box internal volume and alignment type. The maximum volume is already determined by the rear seat height and is 2.25ft^3.
The details
Now he like the Kenwood XR-W10F and I modeled a sealed enclosure in the volume he has. This driver likes a bigger box for flat response. It has a high Q bump at 50-60Hz, but since he likes rock music I thought he migh actually like that bump for the kick drum. I also modeled ported but it didn't yield any significant output and introduced more issues with excursion so I thought better to stick sealed.
I am pretty saavy with HT subwoofers but as far as Car audio i'm a little green. I don't know as much about small cabin gain in a car, and not sure how much extension is really needed in a car sub either so ADVICE IS GREATLY NEEDED. His amp choice works with those subs when wired to 8ohms. I assume the amp is capable of 250WRMS @ 8ohms based on its specs and excursion is under control with 125W/driver in that sealed volume.
He hasn't bought the subs yet, I just wanted to make sure nothing stands out as "just plain wrong" with this design before we move forward and see if another driver choice might work better.
Nicholas
The details
- The enclosure maximum internal volume is 2.25ft^3.
- He wants to spend approx $100-125 for each driver assuming two drivers in this enclosure so figure $250 budget for driver(s)
- He wants to use a Kenwood KAC-9104D he already has.
- His listening preference is Rock, Metal, Classic Rock. Think ACDC, Metallica, Nickelback, shutup i know this music is not very popular these days.
- Mounting depth is shallow at only 6"
Nicholas
