upgrading Polk woofer to Def tech woofer?
I have the CS1 center channel how easy or hard would it be to swap woofers like aren't 5.25" speaker mounting holes all standard like both Polk and Def Tech holes would line up on the CS1 cabinet correct?
was planning on leaving the tweeter and crossover as Polk.
http://www.ebay.com/itm/Definitive-Technology-BP8-BP2X-5-25-Driver-4AAG-/180654472920?_trksid=p5197.m1992&_trkparms=aid%3D111000%26algo%3DREC.CURRENT%26ao%3D1%26asc%3D14%26meid%3D3989137287042101456%26pid%3D100015%26prg%3D1006%26rk%3D1%26sd%3D180654472920%26
the polk cabinet has a tube port vent. the DT cabinet is designed w/ a passive radiating type inclosed type port curious if this has an effect on the woofer?
is this a good plan to add a little umff to the speaker?
Thanks STB
Thanks STB
